What number comes inside the circle?
Can you guess which number comes inside the circle?
Although this looks very easy, the sequence is not very easy. I will post the answer as soon as I find something. Let me know.
    @abrakadabra Sep 6, 2011
    Click on the attachment to enlarge it.
  • Reya
    @reya-SMihdC Sep 15, 2011
    answer is 3.
  • born_star16
    @born-star16-U2z3az Sep 15, 2011
    Answer : 6
    Explanation : Looking at the diagram in rows, the central circle equals half the sum of the numbers in the other circles to the left and right of the centre.
  • Reya
    @reya-SMihdC Sep 16, 2011
    @AKD: What is the right answer?
    @abrakadabra Sep 16, 2011
    Bornstar is correct. She has got the correct explanation too.
    @abrakadabra Sep 23, 2011
    12
    Find the number that should appear instead of the question mark.
  • akhu
    @akhu-BmpTVD Jun 26, 2012
    ans pls...
    @abrakadabra Jun 26, 2012
    Let there be some answer guessing.
  • Vanita Ladkat
    @vanita-3O4Lij Jul 2, 2012
    ans is:3
    Right?
  • Vanita Ladkat
    @vanita-3O4Lij Jul 5, 2012
    sure @Prashnath
    i think its like :
    In first row if we divide circles horizontally and adding numbers in each semicircle then finding difference between calculated addtion for first row its 5,6,7 resp for each circle
    same for second row so that of 1st circle is 2 so next should be 3 so the answer
    but is it right?
  • Vanita Ladkat
    @AKD
    what is right answer?
  • Prashanth_p@cchi
    @prashanth-p-at-cchi-rg0z63 Jul 5, 2012
    vanitaladkatsure @Prashnath
    i think its like :
    but is it right?
    You mean 3 is the the difference and also the answer???
    For Ex: In sec row as you said 2 is obtained by (1+7)-(2+4).
    and 3 is obtained by (9+?)-(6+3). So ? is 3.
    Can be a valid answer, but I think there is a solution and justifies the connection between the circles.
    Anyways, good answer!!! By looking at the arrangement of the circles, it is valid!!!
    Let's see what #-Link-Snipped-# has to say.
    But I think we will have to give another try, before she outs the answer.
    @abrakadabra Jul 5, 2012
    vanitaladkatans is:3
    Right?
    Yes. 3 is the correct answer.
    Using the lower two circles as a source, the values in corresponding segments of the upper left circle equal the sums of the numbers in the lower two circles. The values in the upper central circle equal the products of the values in the lower two circles, and the upper right circle equals the difference between values in the lower two circles.
  • Vanita Ladkat
    @vanita-3O4Lij Jul 7, 2012
    AbraKaDabraYes. 3 is the correct answer.
    ok
    but mine logic was different.
    Anyways i got another way of thinking from this ๐Ÿ˜€
  • Vanita Ladkat
    yes
    Prashanth_p@cchiYou mean 3 is the the difference and also the answer???
    Yes so is 3
    but AKD's logic is different
    And as we all knw 1 question can be solved by different ways
    and different people may come up wid different logic ๐Ÿ˜€
  • nibhani
    @nibhani-wLU5Ju Jul 8, 2012
    AbraKaDabra12
    i think the number is 9 because in first circle 8-7=1 and 10-10=0 and (1*0=0)...same as in 2nd circle..and in 3rd circle and 4th circle if we will perform the same operation then the answer will be 12.so there is a sequence of 0,0,12,12...so the next sequece should be 0 which will be if we use 9 at the place of question mark...am i right?
    @abrakadabra Jul 8, 2012
    #-Link-Snipped-# Answer is 3. Check my post #15 in this thread.
  • Solving the problem with doings this
