What is vibration?
Ankush Sharma
@ankush-FCZUYR โ€ข Oct 26, 2024
hello friends,
I read this on various books and even on google that "Any motion which repeats itself after an interval of time is known as vibration". this simple line explains a lot about vibration. But i have few questions in my mind-
1. Is the rotation of wheel a vibration?
2. if rotation of wheel is not vibration then what about the small particle on the wheel, is that particle vibrating?
3. Is the beat of heart is vibration?
4. Is the movement of piston inside the cylinder is vibration?
5. is the movement of leg or hand of a normal walking person is vibration?
Please answer these questions along with explanation. Thanks
  • zaveri
    @zaveri-5TD6Sk • Feb 26, 2014
    Anku2993"Any motion which repeats itself after an interval of time is known as vibration".
    I think this definition is not entirely correct.
    the examples 1 to 5 are not the examples of vibration.
    one example of vibration would be the motion of the guitar string on excitation. And this is quite different from the cases 1 to 5.
    now consider this example: take a rotating fan. If its blades are dynamically balanced, then the fan will rotate normally. but if any one of the blades is broken or bent, then the fan starts wobbling. this wobbling is what is called vibration.
  • Ankush Sharma
    @ankush-FCZUYR • Feb 26, 2014
    zaveriI think this definition is not entirely correct.
    ok dear thanks for explaining but then according to you what is the definition of vibration?
    and if according to you , the motion of the string of guitar is vibration then it means the cases from 3 to 5 mentioned in my post above are also vibrations. Think upon it once more... waiting.
    @abrakadabra • Feb 26, 2014
    The definition of Vibration as I know it is -
    moving or causing to move continuously and rapidly to and fro.
    Is this incorrect?
  • Anand Tamariya
    @anand-tamariya-DnfjEX • Feb 26, 2014
    Only if the body continues the periodic motion after intial input is removed (like plucking a string), the motion is considered vibration. Else, it's just periodic motion.
  • Ankush Sharma
    @ankush-FCZUYR • Feb 27, 2014
    Anand TamariyaOnly if the body continues the periodic motion after intial input is removed (like plucking a string), the motion is considered vibration. Else, it's just periodic motion.
    dear the example shared by you is of free vibration. But there are also forced vibrations in which there is continuous external force acting on body. So what about it?
  • Ankush Sharma
    Ankita KatdareThe definition of Vibration as I know it is -
    if to fro motion is considered vibration then it means the examples 3 to 5 are vibrations. isn't it?
  • Anand Tamariya
    @anand-tamariya-DnfjEX • Feb 27, 2014
    Anku2993dear the example shared by you is of free vibration. But there are also forced vibrations in which there is continuous external force acting on body. So what about it?
    What's your example of forced vibration?
  • Blv NAGABABU
    @blv-UO1TVQ • Feb 27, 2014
    vibration is once force applied and released then it moves only from mean position to away and towards of equal amplitude. ex:a swinging bed, etc., I think heart is an example for that
  • Ankush Sharma
    @ankush-FCZUYR • Feb 28, 2014
    Anand TamariyaWhat's your example of forced vibration?
    dear the simple result of forced vibration is resonance.
    Now examples
    1. Stringing a guitar- consider that you pluck the string of guitar only once, then the vibration with which string vibrates is free vibration but if keep on plucking the string after releasing it then it is forced vibration. And if the frequency of plucking the string will equal to the natural frequency of string then it becomes resonance.
    2. Pounding a drum- Similarly as above, consider that you strike the drum only once, then the vibration with which the membrane of drum vibrates is free vibration but if keep on striking the membrane after releasing force then it is forced vibration. And if the frequency of striking the membrane will equal to the natural frequency of membrane then it becomes resonance.
    i hope these are simple examples to understand forced vibrations..
  • Ankush Sharma
    Blvn Lakshmanvibration is once force applied and released then it moves only from mean position to away and towards of equal amplitude. ex:a swinging bed, etc., I think heart is an example for that
    dear again the definition provided by you is of only free vibration. if you consider forced vibration then i think 4 and 5 example is also vibration..
  • zaveri
    @zaveri-5TD6Sk • Feb 28, 2014
    In engineering, one such example for forced vibration would be, the vibration of the automobile chassis frame, due to the vibrations of the engine
  • Blv NAGABABU
    @blv-UO1TVQ • Feb 28, 2014
    thinking about 5th example the distance (amplitude) of the leg is not equal u can check 1ce. the front distance covered by the leg is less than the back distance (amplitude) so according to u its not an example for vibration.
  • Blv NAGABABU
    coming to ur 4th example the piston is fixed by two ends I.e., connecting rod to crank and then from crank to crank shaft. but vibration is only about one fixed point and piston is connected to the crank which the position is continously changing.
  • Ankush Sharma
    Blvn Lakshmancoming to ur 4th example the piston is fixed by two ends I.e., connecting rod to crank and then from crank to crank shaft.
    dear it means it is not only forced vibration but forced relative vibration. Right.
  • Anand Tamariya
    @anand-tamariya-DnfjEX • Feb 28, 2014
    Anku2993dear the simple result of forced vibration is resonance.
    Now examples
    The two examples above are due to formation of standing waves. If you have loosened string in guitar or skin on drum, it won't really vibrate, will it?
  • manojCC
    @manojcc-54iJH5 • Mar 2, 2014
    Anku2993hello friends,
    I think vibration is to and fro motion of an object or body and vibration can be defined as some form of disturbance.....
  • Sekocan
    @sekocan-lo93ZL • Mar 12, 2014
    Vibration must happen as oscillation, like a sine wave. It must be around some origin and if the external forces are removed (and after some dampening, resistance, loss of energy...) it must stabilize itself on that origin.
    It can be periodic (like the guitar string and most of the natural frequency vibrations) and it can be random (like a car on a gravel road).
    I don't know if there is a difference between vibration and oscillation. But I know that vibration is a subgroup of oscillation.
    Wikipadia says this: " The term <a href="https://en.wikipedia.org/wiki/Vibration" target="_blank" rel="nofollow noopener noreferrer">Vibration</a> is sometimes used more narrowly to mean a mechanical oscillation but is sometimes used as a synonym of "oscillation". Oscillations occur not only in mechanical systems but also in <a href="https://en.wikipedia.org/wiki/Dynamic_system" target="_blank" rel="nofollow noopener noreferrer">Dynamic System</a> in virtually every area of science: for example the beating <a href="https://en.wikipedia.org/wiki/Human_heart" target="_blank" rel="nofollow noopener noreferrer">Human Heart</a>, <a href="https://en.wikipedia.org/wiki/Business_cycle" target="_blank" rel="nofollow noopener noreferrer">Business Cycle</a> in <a href="https://en.wikipedia.org/wiki/Economics" target="_blank" rel="nofollow noopener noreferrer">Economics</a>, <a href="https://en.wikipedia.org/wiki/Predator-prey" target="_blank" rel="nofollow noopener noreferrer">Predator Prey</a> population cycles in <a href="https://en.wikipedia.org/wiki/Ecology" target="_blank" rel="nofollow noopener noreferrer">Ecology</a>, geothermal <a href="https://en.wikipedia.org/wiki/Geyser" target="_blank" rel="nofollow noopener noreferrer">Geyser</a> in <a href="https://en.wikipedia.org/wiki/Geology" target="_blank" rel="nofollow noopener noreferrer">Geology</a>, vibrating strings in <a href="https://en.wikipedia.org/wiki/Musical_instrument" target="_blank" rel="nofollow noopener noreferrer">Musical Instrument</a>, periodic firing of <a href="https://en.wikipedia.org/wiki/Nerve_cell" target="_blank" rel="nofollow noopener noreferrer">Nerve Cell</a> in the brain, and the periodic swelling of <a href="https://en.wikipedia.org/wiki/Cepheid_variable" target="_blank" rel="nofollow noopener noreferrer">Cepheid Variable</a> stars in <a href="https://en.wikipedia.org/wiki/Astronomy" target="_blank" rel="nofollow noopener noreferrer">Astronomy</a>."
    I believe if you want to call an oscillation "vibration", it should have a relatively high frequency like a guitar string (not like a celestial motion).
    In Turkey, if a mechanical engineer sees a machine starting to vibrate in one of its natural frequencies, he/she says: (direct translation) "It entered oscillation (phase)"
