  • sauravgoswami
    @sauravgoswami-UAfTlI • Mar 13, 2008
    Re: What is the difference between MEMS and Nano?
    MEMS is combination of electronic and mechanical system in a single chip,while nanotechnology consist of eveyrthing which of nanometre lenght,even chemical,physical and biological systems,anyhow MEMS are bigger than nano-systems.guys,pls comment and correct
  • Ashraf HZ
    @Ash • Mar 13, 2008
    sauravgoswamiMEMS is combination of electronic and mechanical system in a single chip,while nanotechnology consist of eveyrthing which of nanometre lenght,even chemical,physical and biological systems,anyhow MEMS are bigger than nano-systems.guys,pls comment and correct
    Thats about it. A MEMS chip consists of different parts; the microelectronics,the microsensors, microactuators, microstructures, and are fabricated together using microfabrication techniques (like IC's). The benefits of MEMS are limitless!
    I believe the basic difference between MEMS and Nanotechnology is the size: MEMS are typically between a micrometer (10[sup]-6[/sup]m) and a millimeter (10[sup]-3[/sup]m), while nanotech is in the nanometer scale (10[sup]-9[/sup]m). Because we go down to such a small scale, we make use of the properties of the materials down at the nanoscale.
    Partly taken from here: #-Link-Snipped-#
    I recommend taking a look at some IEEE journals regarding this too:
    <a href="https://ieeexplore.ieee.org/xpl/RecentIssue.jsp?punumber=84" target="_blank" rel="nofollow noopener noreferrer">Journal of Microelectromechanical Systems | IEEE Xplore</a>
  • eccentronix
    @eccentronix-n19Tvv • Apr 13, 2008
    Basically yes... what ash says....
    It's quite amazing though... We can achieve remarkable sensitivities and precision using the MEMs technology when it comes to electromechanical sensor and actuators. For eg., consider the accelerometer...its made up of a spring, a mass and a damper... the natural frequency is given by sqrt(k/m).. that means, when the mass is taken to the 'micro' level, you have an extremely sensitive accelerometer with great resolution.. Its amazing, MEMs...
    As far as Nanotech is concerned, when you're down to the nano scale, everything is in its 'primordial' form. It's all broken down to the level of bio-chemo-physical molecules. There are a few researchers at my university who have done breakthrough research in this field. We recently bought a Nano-Indentation machine as well. Also, its usually the materials engineers with a know-how in biochemistry who usually pursue this research. Also, your maths has to be great.
