What is the difference between hyper-threading multi-threading and super-threading in
sruti
@sruti-mfWaFK Oct 26, 2024
As per my knowledge Hyperthreding technlogy is used in P4 CPU's. [ whenever U open multiapplication i.e. more than one prog. if 2 prog runs at the same time this tech uses 2 cpu work for two programs & is supported only by Windows Xp. ]
Multithreading is more than one prog. running by same cpu and assining & allocating prog. by time slicing tech.
Edit (The Big K): Removed Advertisement.
  • miteshmanani
    @miteshmanani-5xYEsh Apr 13, 2007
    Re: What is the difference between hyper-threading multi-threading and super-threadin
    Hi sruti,
    Multithreading, also called concurrency, is a programming language feature which allows the programmer to construct multiple independent "threads" of execution. This allows applications to be executing multiple functions simultaneously, and can be a useful programming model in many situations. For instance, you might want an application to be able to perform a complex operation such as loading a file from disk without hanging its user interface. In this case, the file-loading function could be in a separate thread from the user interface functions.
    Java language has most well defined libraries that can be used for Threading and Multi Threading.
    Hyper-Threading works by duplicating certain sections of the processor—those that store the architectural state—but not duplicating the main execution resources. This allows a Hyper-Threading equipped processor to pretend to be two "logical" processors to the host operating system, allowing the operating system to schedule two threads or processes simultaneously. Where execution resources in a non-Hyper-Threading capable processor are not used by the current task, and especially when the processor is stalled, a Hyper-Threading equipped processor may use those execution resources to execute another scheduled task.
    Super-threading is a form of multithreading, that appeared in Pentium processors prior to the introduction of hyperthreading.In super-threading, the processor can execute instructions from a different thread each cycle. Thus cycles left unused by one thread can be used by another that is ready to run. Still, a given thread is almost surely not utilizing all the multiple execution units of a modern processor at the same time. More advanced implementations of SMT allow multiple threads to run in the same cycle, using different execution units of a superscalar processor.
    With Regards,
    Mitesh Manani
