@brajeshkumar-GiRicY • Nov 23, 2011
AS my knowledge there is some proccess
1.inner querry
2.join query
3.using specific keyword(like max ,min) -
@praveenkumar-66Ze92 • Dec 21, 2011
A few techniques of Query Optimization are:
1. Faster SELECT query, when you use the actual column names instead of '*'.
Original SQL Code:SELECT id, first_name, last_name, age FROM member_details;
Optimized SQL Code:
SELECT * FROM member_details;
2. HAVING clause is used to filter the rows after all the rows are selected. It is just like a filter. Do not use HAVING clause for any other purposes.
Original SQL Code:SELECT subject, count(subject) FROM student_details GROUP BY subject HAVING subject!= 'Vancouver' AND subject!= 'Toronto';
Optimized SQL Code:
SELECT subject, count(subject) FROM student_details WHERE subject != 'Science' AND subject != 'Maths' GROUP BY subject;
3. Sometimes you may have more than one sub-queries in your main query. Try to minimize the number of subquery block in your query.
Original SQL Code:SELECT name FROM employee WHERE salary = (SELECT MAX(salary) FROM employee_details) AND age = (SELECT MAX(age) FROM employee_details) AND emp_dept = 'Electronics';
Optimized SQL Code:
SELECT name FROM employee WHERE (salary, age ) = (SELECT MAX (salary), MAX (age) FROM employee_details) AND dept = 'Electronics';
4. Use operator EXISTS, IN and table joins appropriately in your query.
Original SQL Code:Select * from product p where product_id IN (select product_id from order_items)
Optimized SQL Code:
Select * from product p where EXISTS (select * from order_items o where o.product_id = p.product_id)
5. Use EXISTS instead of DISTINCT when using joins which involves tables having one-to-many relationship.
Original SQL Code:SELECT DISTINCT d.dept_id, d.dept FROM dept d,employee e WHERE e.dept = e.dept;
Optimized SQL Code:
SELECT d.dept_id, d.dept FROM dept d WHERE EXISTS ( SELECT 'X' FROM employee e WHERE e.dept = d.dept);
@manish-r2Hoep • Dec 22, 2011
Adding a index to a column is also a good way to optimize your search query
for eg if you have database having table say A
having attributes such as city, state, address , then you can add index to these to make your search fast
2:- Always try to avoid unwanted parenthesis in your query
