What is mechanism behind moving toys
rajshekhar k h
rajshekhar k h
@rajshekhar-k-h-5yBoGj Oct 19, 2024
suggest me the mechanism that is responsible for moving of toys when it is keyed..... if possible suggest sites so that i can get real picture....
  • Jeffrey Arulraj
    Jeffrey Arulraj
    @jeffrey-xA7lUP Nov 9, 2012
    The Newton's law "Every action has an equal and opposite reaction" holds good
    When you coil the spring there is a lot of tension on it the moment you release it the force already exerted is reacted upon and the toy moves forward
  • rahul69
    rahul69
    @rahul69-97fAOs Nov 9, 2012
    When the toy is keyed, the energy is stored inside the spring (theoretically (1/2)kx^2). This energy is released by rotating the tires and hence moving the toy.
  • zaveri
    zaveri
    @zaveri-5TD6Sk Nov 9, 2012
    the key is attached to a torsional spring, which is disturbed on keying, when the key is released, it starts unwinding, and this is what rotates the axle shaft of a toy car.
    @thebigk Nov 9, 2012
    I'm not sure if there's a special name to the energy stored in a compressed spring; but I'd call it potential energy which gets converted into Kinetic Energy through the movement of the wheels. But is that the real question being discussed here?
  • zaveri
    zaveri
    @zaveri-5TD6Sk Nov 10, 2012
    The_Big_K
    what you have said is right.
    springs and flywheels come under a class of machine elements called ENERGY STORAGE DEVICES.
    when a spring is disturbed , or loaded in anyway, work has to be done to do this. the amount of work done to this is what is stored as energy in the spring, and this energy is released, whenever the load is removed from the spring.
  • rajshekhar k h
    rajshekhar k h
    @rajshekhar-k-h-5yBoGj Nov 10, 2012
    actually i am doing project on this...........
    please suggest me how exactly the link has been done to convert energy stored in coil to kinetic energy
  • zaveri
    zaveri
    the key shaft is placed inside the coil spring such that their axes coincide, and that the outer surface of the shaft tightly hugs the internal surfaces of the spring.
    the ends of the spring, are rigidly fixed.
    on one end of the key shaft, is attached the key, and the other end is present the wheel.
    the key is to provide leverage while twisting(keying).
    when you have twisted the key in any one direction, say clockwise and release it, the spring unwinds and rotates the key shaft in the opposite direction (ccw).
    but for this it is important that the ends of the spring are tightly clamped.
