WHAT IF 64-BIT DRIVERS ARE INSTALLED IN A 32-BIT SYSTEM?
S.A.SREEJITH
@sasreejith-63idqU โ€ข Oct 19, 2024
Is the bit system of a machine an important criteria for installing drivers?
What actually happens during proper and improper installation of drivers?
    @anoop-kumar-GDGRCn • Dec 20, 2012
    Its depends on how software coded..
    A 64 bit processor or software is designed to calculate 64 bits parallely.
    In general practice all 32 bit softwares are compatible with 64 bit but not in reverse.
    In case of incompatibility of program , it can corrupt your system files. Better make restore point.
  • S.A.SREEJITH
    @sasreejith-63idqU • Dec 20, 2012
    But i've installed 64 bit drivers in 32 bit system.few are working correctly.Will it cause any problems in future?????
    If it doesn't having problem right now then surely will be fine, Its software not a Nut-bolt๐Ÿ˜€
