What happens when supply is given to a permanent magnet?
Mr.Don
@mrdon-92OwlG โ€ข Oct 27, 2024
CEans, I have a crazy doubt
What will happen if the supply is given directly to the permanent magnet?
  • ISHAN TOPRE
    @ishan-nohePN • May 9, 2011
    You mean that you are going to wound wire around magnet and then give supply?
    Or do you want to give direct supply? In second case I think nothing will happen. I do not know much but nothing will happen, I think.
  • Mr.Don
    Mr.Don OP
    @mrdon-92OwlG • May 9, 2011
    Yeah no wounding of wire.
  • everett.pattison
    @everettpattison-3yhnjP • May 9, 2011
    I do not think anything will happen, unless there is a coil there won't be any kind of electrically induced magnetic field nor do I think it will inhibit the magnets field. Someone with a chemistry background may be able to answer this question better.
  • PraveenKumar Purushothaman
    @praveenkumar-66Ze92 • May 9, 2011
    Well, that's what is happening in the case of electric bell or dynamo... It goes forward if positive and goes back if negative...
  • everett.pattison
    The electric bell or dynamo function off electromagnets which in its most basic form, is a coil of wire wrapped around an iron core which produces the magnetic field, permanent magnets are not used let alone have voltage put through them.
    everett.pattisonThe electric bell or dynamo function off electromagnets which in its most basic form, is a coil of wire wrapped around an iron core which produces the magnetic field, permanent magnets are not used let alone have voltage put through them.
    Permanent Magnet is used in these cases for getting repulsion!
    [โ€‹IMG]
  • everett.pattison
    That is not an electromagnet though. There is no voltage being applied to it as the original poster was asking. That system is used to create voltage/current.
    Man! Only when both permanent and elecromagnet are together, dynamo or motor works! Don't you know that?
  • everett.pattison
    @everettpattison-3yhnjP • May 10, 2011
    You're not listening to what I'm saying, the original question is what happens when you apply voltage to a permanent magnet. Never in any of those applications do you apply voltage to a permanent magnet.
    @praveenkumar-66Ze92 • May 10, 2011
    So you mean to say, applying voltage to the magnet and not to a coil and wrapping it on a magnet! Right? If this is the case, then the magnet itself is a conductor performing a short circuit... ๐Ÿ˜€
    @ramani-VR4O43 • May 10, 2011
    praveenscienceSo you mean to say, applying voltage to the magnet and not to a coil and wrapping it on a magnet! Right? If this is the case, then the magnet itself is a conductor performing a short circuit... ๐Ÿ˜€
    You are right.
    If it is a metallic magnet (AlNiCO for example), it is like any other conductor and will carry a current. This will create a magnetic field around the magnet whose sign will depend on the direction of current according to Fleming's Rule. This may enhance or detract from the permanent magnet's own field if a DC. If AC the effect will be cyclic at the frequency of the supply. If it is a ceramic magnet it will not conduct.
    Biormanai
  • everett.pattison
    Yes, that is what '#-Link-Snipped-#' was trying to ask, not talking about electric bells and dynamos.
    bioramaniYou are right.
    Biormanai
    Magnet can only be Iron (Fe) right??? And even a kid knows that Iron is a good conductor of electricity. Then, it is evident that it makes a short circuit. What is ceramic magnet then?
    By the way, your signature is wrong! ๐Ÿ˜”
    praveenscienceMagnet can only be Iron (Fe) right??? And even a kid knows that Iron is a good conductor of electricity. Then, it is evident that it makes a short circuit. What is ceramic magnet then? By the way, your signature is wrong! ๐Ÿ˜”
    As Shakespeare (according to some die hard Tamils, he was a Tamil called ร ยฎยœร ยฏย†ร ยฎย•ร ยฎยšร ยฎยฟร ยฎยฑร ยฏยร ยฎยชร ยฎยฟร ยฎยฏร ยฎยฉร ยฏย, who migrated to London!) said, 'what's in a name?'
    Magnets can be made out of any ferromagnetic material.
    Ceramic ones are electrical insulators.
    Bioramani
    (made sure of that!)
    bioramaniAs Shakespeare (according to some die hard Tamils, he was a Tamil called ร ยฎยœร ยฏย†ร ยฎย•ร ยฎยšร ยฎยฟร ยฎยฑร ยฏยร ยฎยชร ยฎยฟร ยฎยฏร ยฎยฉร ยฏย, who migrated to London!) said, 'what's in a name?'
    Bioramani
    Thank you sir... Learnt something new... I too had a magnet which was very flexible, and am damn sure it is not Iron! ๐Ÿ˜› Would it be ceramic then???
    praveenscienceThank you sir... Learnt something new... I too had a magnet which was very flexible, and am damn sure it is not Iron! ๐Ÿ˜› Would it be ceramic then???
    It must be one of the magnets made of ceramic powder in a flexible polymer matrix, commonly used as promotional material (Fridge stickers) or presentation graphics.
    Bioramani
  • amar.amar
    @amaramar-EBl7G3 • May 13, 2011
    i think its polarities might change due to the electric current..
    @praveenkumar-66Ze92 • May 13, 2011
    amar.amari think its polarities might change due to the electric current..
    Hoi! Where are polarities coming in magnets???
  • amar.amar
    it has the poles naa north and south!!
    amar.amarit has the poles naa north and south!!
    Man! These permanent poles never change for sure!!! ๐Ÿ˜ฒ
  • Mr.Don
    Mr.Don OP
    @mrdon-92OwlG • May 20, 2011
    Biormanai
    Why metallic conduct and Ceramic magnets don't conduct. Where is the energy going in ceramic magnets?
    @praveenkumar-66Ze92 • May 20, 2011
    dileep kWhy metallic conduct and Ceramic magnets don't conduct. Where is the energy going in ceramic magnets?
    They are not metals... Only metals are capable of conducting electricity... ๐Ÿ˜€
  • venueee
    @venueee-u2olIi • May 20, 2011
    due to the application of electrical energy on permenent magnet ,it will lossse or reduces the magnitic strenth.......
    @harshad-ukH5ww • May 20, 2011
    venueeedue to the application of electrical energy on permenent magnet ,it will lossse or reduces the magnitic strenth.......
    Before that it should conduct the electrical energy right?
  • Mr.Don
    Mr.Don OP
    praveenscienceThey are not metals... Only metals are capable of conducting electricity... ๐Ÿ˜€
    Hey that is a question to Bioramani sir's Answer.Metallic magnets will conduct and I wanted to know why ceramic magnets don't conduct. If they conduct then where's the energy going.
    @ Praveen I think we can safely jump into the water with an electric wire in it now ๐Ÿ˜›
    @praveenkumar-66Ze92 • May 21, 2011
    Why? You wanna die??? ๐Ÿ˜›
  • Mr.Don
    Mr.Don OP
    @mrdon-92OwlG • May 21, 2011
    @Praveen Noo.I don't wanna die and I cannot die because only metals can conduct. ๐Ÿ˜›
    Dude you said tying up a wire... Wire conducts... ๐Ÿ˜€
  • narayana murthy
    @narayana-z4W16q • May 21, 2011
    hahahaha guys inside wire we are having a conductor observe it
    as well gold, copper such metals are good conductors due to less availability we use some combination alloy materials for transmission so we use them for transmission
    narayana murthyhahahaha guys inside wire we are having a conductor observe it
    Yes,,, So???
  • narayana murthy
    praveenscienceYes,,, So???
    wire conducts
    That's what even I said... ๐Ÿ˜›
  • narayana murthy
    praveenscienceThat's what even I said... ๐Ÿ˜›
    but thats not concentrated with you praveen hahaha
    ok @dileep: ceramic magnets means farrite right they are materials which gets energies when others gives power to energize
    i think this may help here
    narayana murthyceramic magnets means farrite right they are materials which gets energies when others gives power to energize
    That's a new fact here... Thanx... And Dil is always thinking of dying, isn't it???
  • narayana murthy
    praveenscienceThat's a new fact here... Thanx... And Dil is always thinking of dying, isn't it???
    hahaha may be but he always saying i don't want to die so pity
    just kidding
    narayana murthyhahaha may be but he always saying i don't want to die so pity
    just kidding
    I seriously don't understand how much we are TJing... ๐Ÿ˜› Yeah, that's the talent of Dil!
  • Mr.Don
    Mr.Don OP
    @mrdon-92OwlG • May 22, 2011
    praveenscienceI seriously don't understand how much we are TJing... ๐Ÿ˜› Yeah, that's the talent of Dil!
    hehe You TJing me ๐Ÿ˜› ๐Ÿ˜
    No one can Tease Don. ๐Ÿ˜Ž
    @NM Thanks NM. ๐Ÿ˜€
    @ramani-VR4O43 • May 22, 2011
    dileep kI wanted to know why ceramic magnets don't conduct. If they conduct then where's the energy going. @ Praveen I think we can safely jump into the water with an electric wire in it now ๐Ÿ˜›
    Dileep we need free electrons (or 'holes' as in semiconductors) to conduct electricity. Ceramics do not have them. So they are insulators.
    You may be right about jumping into a pool with a live wire dipped in it. Provided the the person jumping in is not connected with a good ground wire, no current passes through the person. One can hang from a 11 KV live wire safely so long as he is isolated. Human body does have some conductivity. On a wet surface 220 V can be fatal. More than a few microns directly through the heart can kill.
  • praba230890
    @praba230890-vPFAoQ • May 26, 2011
    dileep kCEans, I have a crazy doubt
    It depends on the exact situation.
    Generally, unless the current is strong enough to cook the magnet, the magnet doesn't change.
    The current on the other hand, may take a more curved route through the magnet, due to the magnetic field (magnetic fields push current around).
    Is that what you were asking about?
  • praba230890
    bioramaniDileep we need free electrons (or 'holes' as in semiconductors) to conduct electricity. Ceramics do not have them. So they are insulators.
    Your swimming pool example is so fatal as there must be any ground contact in the swimming pool as swimming pools are concrete erected on bare ground. But your answer is so informative.
  • aj_onduty
    @aj-onduty-BvuwMK • Jun 1, 2011
    Coming back to the question.. if you don't mind spoiling the fun.
    The question is what happens when supply is given to a permanent magnet.
    The answer is, "depends".
    It depends on the material of which the magnet is made of. If it is a metal, metals like cobalt, nickel, iron etc.(ferromagnetic materials are magnets... that is what they taught me.), it will conduct a current just as it conducts in a normal conductor. If it is not a conducting material, well, it simply won't.
    Now, talking about the change of poles and things. If you observe closely in a magnet(well not with your eyes, I am talking about the atomic-subatomic levels), each atom acts as a magnet. All those atoms align in exactly the same way (ideally) to create a large magnet(large enough for you to see, touch and use). The strength of the magnet depends on how many of these atoms are aligned.
    Now, if you can use some force to 'divide and rule', you can alter the magnetic status, I mean, the polarity of the magnet. If the voltage you are applying is such that the direction of the magnetic field induced by it is against the magnetic field of the magnet, and is higher in value of the same, then the polarity of the magnet also changes. Please note that this will happen if and only if the magnet conducts electricity.
    Hope I have clarified your doubts.
    P.S.- Moderators, Please do think about doing a bit more moderation, Clean up this thread of unnecessary posts, please.
  • durga ch
    @durga-TpX3gO • Jun 1, 2011
    @ AJ
    As moderators we can only delete spam. If users dont want to hold the discussion in a relevant method, mods are not responsible for editing the thread as well the users are all regular users . We do warn when it is needed or some one is spamming.
    Though it is responsibily of MODs to keep the palce clean, is is as well the responsiblity of CEans not to soil it. As someone rightly said -" Even a daimond cannot be found in a ton of coal".
  • aj_onduty
    durga@ AJ
    As moderators we can only delete spam. If users don't want to hold the discussion in a relevant method, mods are not responsible for editing the thread as well the users are all regular users . We do warn when it is needed or some one is spamming.
    Though it is responsibly of Mods to keep the place clean, is is as well the responsibility of CEans not to soil it. As someone rightly said -" Even a diamond cannot be found in a ton of coal".
    (I know you all are busy, but...) At least when people post something, the Mods can actually pm them and ask them to either edit the post or ask them if Mods can delete them if the posting member also feels that the post is not relevant to the topic.
  • ISHAN TOPRE
    @ishan-nohePN • Jun 1, 2011
    @ Durga,
    There are many simple posts in this thread which can be deleted and no one would mind it. Let alone responsibility and other things. No one will mind it. Please delete unwanted posts. (Including this one. Sorry for spamming) ๐Ÿ˜€
  • Mr.Don
    Mr.Don OP
    @mrdon-92OwlG • Jun 4, 2011
    Thanks Aj. You surely had clarified my doubt. ๐Ÿ˜€
    @Aj: Thanks Aj I will think twice to post something after this but don't worry moderators will definitely do their moderation. ๐Ÿ˜€
    @Ishan: Come on Ishan don't spam yourself man just PM a moderator. ๐Ÿ˜› ๐Ÿ˜€
