Voice based activation and control of system devices -using 89c51
alexantony
@alexantony-CqWkm2 Oct 26, 2024
i'm a final year engg. student .
i plan to do a project in embedded systems
"Voice based activation and control of system devices "-using 89c51
i need ideas in this region ....
  • aashima
    @aashima-eO93l9 Aug 28, 2008
    alexantonyi'm a final year engg. student .
    Is that an AT IC? What all components or techniques are you planning to implement?
  • alexantony
    @alexantony-CqWkm2 Aug 28, 2008
    i am using AT 89c51 .
    The project aims at controlling devices through voice input. .The simple voice tags given through the microphone controls the whole external devices.
    i want to use VB as its front end...
  • anuragh27crony
    @anuragh27crony-mb8hAE Aug 28, 2008
    alexantony i am using AT 89c51 .
    If you are using At89c51 ...then Keil C would be helpful in programming.... have a look..it gives you much flexibility in programming
  • aashima
    @aashima-eO93l9 Aug 30, 2008
    Keil C would work perfectly but if none of you has any knowledge of it, it'll be tough learning it in a short time, you may use IDE 8051 in that case, its easier and good for a newbie.
