@raj87verma88-ZpL2Wn • May 2, 2008
Rather difficult
But let me give it a shot
cos-1 (inverse) 0 = 90
√90 = 9.5
and 3√90 = 4.5
√cos (inverse) 0 + √cos (inverse) 0 + √cos (inverse) 0 -3√cos (inverse) 0
= √90 + √90 + √90 - 3√90
= 9.48 +9.48 + 9.48 – 4.48
= 28.44 – 4.48
= 23.9
after taking square root and cube root if we approximate
that is
9.5 + 9.5 + 9.5 – 4.5
then answer is exactly 24
How about it Biggie -
Also instead of cube root of 90 we can do
ln90 = 4.49 -
@thebigk • May 2, 2008
Hint -
K.I.S.S 😁
...and since when did we start relying on 'approximate' values?
On the same lines, I've another question -> is 0.999999...(infinite times) equal to 1 ?
If yes, how? If not, why? 😉 -
@devesh-f6jAzZ • May 4, 2008
do we only have to use 0's?
I mean nothing else(no other numerics),only operators and zeroes!!! -
@thebigk • May 4, 2008
Yes, that's right. Only four zeros! (and of course, mathematical operators).
Is it really 'that' difficult? -
@gohm-F3UUpP • May 4, 2008
Are we allowed to rotate the operators?
Nope, it is never equal to 1. Only 1 is equal to 1. In most practical uses it is close enough mathematically to round the .99999 to 1 however it is never actually equal to 1.
The_Big_KHint -
K.I.S.S 😁
1. No, you cannot 'rotate' operators. Come on, its just basic mathematics!
2. If 0.99999...(infinite) is not equal to one, what's wrong with the following? -
x = 0.99999...(infinite times)
10x = 9.9999.......
=> 9x = 9
=> x = 1
What say? 😉 -
Here is your problem, the tricky business between the 10x=9.999999... and then 9x=9. Did you change the value of x?
The_Big_K1. No, you cannot 'rotate' operators. Come on, its just basic mathematics!
10x = 9.9999.......
=> 9x = 9
=> x = 1
What say? 😉 -
gohmHere is your problem, the tricky business between the 10x=9.999999... and then 9x=9. Did you change the value of x?
Umm, okay, here we go -
x = 0.99999...(infinite times) - Equation (A)
10x = 9.9999....... - Equation (B)
Equation (B) minus (A)
=> 9x = 9
=> x = 1
@mahul-ZxpiLA • May 4, 2008
Four zeroes to score 24, that's easy-->>
(0!+0!+0!+0!)!=24
i hope that would do, unless _k has a problem with my repeated use of factorials 😀 -
mahulFour zeroes to score 24, that's easy-->>
(0!+0!+0!+0!)!=24
i hope that would do, unless _k has a problem with my repeated use of factorials 😀Hah, no problem with factorials! That's the right way to get 24. Pretty easy, eh? 😀
