USBtoSerial Converter
Harshad Italiya submitted a new project:
#-Link-Snipped-# - Low cost USB to Serial Converter
USBtoSerial
​USB to Serial is a low cost, easy to use and multipurpose device. Now a days we are running out of Serial COM port on PC and Laptop. As the name suggest, using this USB to Serial you can use your USB port as a Serial COM port. It supports USB to UART 3.3V, USB to UART 5V and USB to RS232 conversion including hardware flow control.
It also have Xbee compatible socket where you can connect any compatible breakout board and have a access directly...
  • themask
    @themask-kPDDPY • Jun 17, 2014
    How this differs from a readily available product (USB to Serial adapter).
    I've negligible knowledge in Electronics. But interested in that to learn.
    @harshad-ukH5ww • Jun 17, 2014
    themaskHow this differs from a readily available product (USB to Serial adapter).
    First of all it's price far less than the available in market + It has ZigBee adapter so you can directly put Zigbee compatible modules on this board and start hands-on.
    One more thing is adapter available in market has no option for 3.3 and 5v TTL signal but on this board you can have that.
  • themask
    @themask-kPDDPY • Jun 18, 2014
    Thanks for the reply. How can I make one for myself?
    @harshad-ukH5ww • Jun 18, 2014
    themaskThanks for the reply. How can I make one for myself?
    You can buy one if you want to use. 😀
  • DADISETTY GOVIND
    @dadisetty-e8Qu7A • Aug 15, 2014
    whats this serial converter why it is used
    @harshad-ukH5ww • Aug 15, 2014
    DADISETTY LAXMI GOVINDwhats this serial converter why it is used
    It is used to convert serial data you can also say TTL signal into USB which basically creates virtual com port.
  • barath rajamani
    @barath-uBS8aH • Aug 17, 2014
    but most of these which we get in market doesnt work... only few and rare and not for all applications..
    @harshad-ukH5ww • Aug 18, 2014
    bobgallebut most of these which we get in market doesnt work... only few and rare and not for all applications..
    Yeah ! They are cheaper one. You know this board also have RS232 and TTL both option. So whatever your end device is you can still view the data on PC/Laptop by USB port.
