tyres which can take metal from road by electrical means
ameen0303
@ameen0303-7hQGXJ โ€ข Oct 23, 2024
Is it possible to make tyres which left or pick metal which causes puncture,damage,etc.,
while driving!
i have an idea,magnet can lift metal but how can it be applicable?๐Ÿ˜”
from two wheel to four wheel.
I) HOW IT CAN BE DESIGN?
II) STORAGE SYSTEM ?
III) MECHANISM?
IV) OTHER FACTOR etc,๐Ÿ˜’
  • Gurjap
    @gurjap-blPmg9 • Aug 20, 2011
    you need to explain a little bit. are you talking about suspending a magnet in front of the tire so it will pick up metallic bits before the puncture the tire?
    if yeah, you are probably looking for a neodynium-based permanent magnet, or some electromagnet driven by the vehicle alternator... uh, battery, because I think the alternator makes ac current ๐Ÿ˜›
    anyway, you'll need to find out how much strength the magnet will need to have.
  • ISHAN TOPRE
    @ishan-nohePN • Aug 20, 2011
    No, I second Gurjap. (sorry mate)
    He is partly true. You can have a magnet, but if we pick up every metal particle from roads, and it remains sticking to tyres, tell me is it practical?
    Instead we should have a mechanism which will make metal pieces to leave the path of your car.
    Let us say we can have an air blowing mechanism which will blow away those particles safely. ๐Ÿ˜€
  • ShrinkDWorld
    @shrinkdworld-WWdBBc • Aug 20, 2011
    In both the cases we have to consider very important parameter i.e, speed. At higher speed you strong magnetic field & strong blower. We have very less time to do this thing.
  • Gurjap
    @gurjap-blPmg9 • Aug 21, 2011
    @ gg_gaurav - true enough. but it's still fun to consider ๐Ÿ˜€
    I don't think we'll able to make a simplistic mechanism which will be worth the money. There is always that radiation-based mechanism which will detect the metal beforehand, prepare the removal mechanism and take it out in time. Will it be worth the money?
  • Keerthivasan Ravisankar
    @keerthivasan-hrKQir • Sep 26, 2011
    No idea...๐Ÿ˜ฒ
  • zaveri
    @zaveri-5TD6Sk • May 26, 2012
    can use the principle of electromagnetism
  • NAVATHE SACHIN
    @navathe-8fNDWG • May 27, 2012
    In these days the tyres are made tubeless.so,using this mechanism is not necessary.
    @ramani-VR4O43 • May 28, 2012
    Abetter idea will be for a cleaning agency to magnetically sweep the roads at off peak hours at a much slower speed. Even then only ferrous sharps will be picked up. Non magnetic glass/ceramic/nonferrous sharps will not be.
