Try The 'C' Code !
Here comes a challenge for Computer Engineers !
int i, n = 20;
for (i = 0; i < n; i--)
printf("X");
By only changing or adding ONLY ONE character to the above code:
Find 3 ways to make the above code print X 20 times!
-The Big K-
p.s: This challenge will be open for all CEans untill someone cracks it. Do *not* expect an answer from me.
  • sristi
    @sristi-483Qff • Jun 15, 2006
    1)
    int i, n = 20;
    for (i = 0; i < n; i++)
    printf("X");
    2)int i,n=20;
    for(i=0;i++<n๐Ÿ˜‰
    print("X");
    3)
    int i, n = 20;
    for (i = 0; ++i < =n; )
    printf("X");
    @thebigk • Jun 15, 2006
    That was a nice attempt [โ€‹IMG]
    But you missed this -
    ๐Ÿ˜‰
    -The Big K-
  • Jerry
    @jerry-5wPKU7 • Jun 15, 2006
    working on it
    sristi1)
    int i, n = 20;
    printf("X");
    yeh, you changed -- to ++ , that is you changed two characters. However you are allowed to change only one chracter from the code. Really interesting, I'm working on it !๐Ÿ˜‰
  • crook
    @crook-0PFkJv • Jun 16, 2006
    I'm not a C programmer but this is more of a logic problem. Should not take more time. Let me see what can I do about it.
    crook
    @thebigk • Jun 16, 2006
    probably I should start giving out hints!
    Cummont fellaz, do you really need them? [โ€‹IMG]
    -The Big K-
  • crook
    @crook-0PFkJv • Jun 17, 2006
    got it
    i think i got it.
    in the original code, make the following change
    for (i = 0; i < n; n--)
    it should work! now trying the remaining two methods ๐Ÿ˜
  • crook
    @crook-0PFkJv • Jun 24, 2006
    here comes the second way - ๐Ÿ˜
    int i, n = 20;
    for (i = 0; -i < n; i--)
    printf("X");
    and the third ๐Ÿ˜
    int i, n = 20;
    for (i = 0; i + n; i--)
    printf("X");
  • crook
    New Challenge !
    This is a simple C puzzle for you -
    "Write a "Hello World" program in 'C' without using a semicolon."
    Try it, its very simple.
    CrooK
  • Jerry
    @jerry-5wPKU7 • Jun 25, 2006
    int i, n = 20;
    printf("X");
    will this work? ๐Ÿ˜’
    I don't have a compiler to try this out. I have started working on crook's problem. Its been quite sometime since I letf coding ๐Ÿ˜”
  • pradypop
    @pradypop-Draqkg • Jun 28, 2006
    main(){if(printf("Hello world")){}}
    This might print hello world. No semi-colons used.
  • crook
    @crook-0PFkJv • Jun 28, 2006
    yes, thats a correct solution! ๐Ÿ˜€
  • rajeshkumar.km
    @rajeshkumarkm-JkfM7A • Aug 7, 2006
    my guesss
    ๐Ÿ˜‰
    int i, n = -20;
    printf("X");
    i think the above change ( minus sign before 20 in the line 'int i,n=20')will respond to your view correctly
  • crook
    @crook-0PFkJv • Aug 8, 2006
    rajeshkumar.km๐Ÿ˜‰
    int i, n = -20;
    printf("X");
    ๐Ÿ˜• I'm afraid the logic won't work.
    Croook
  • devi prasad
    @devi-prasad-rBHPuv • Aug 10, 2006
    ans:
    first method:
    int i, n = -20;
    printf("X");
    second method :
    int i, n = 20;
    for (i = 0; i < -n; i--)
    printf("X");
    third method:
    int i, n = 20;
    for (i = 20; i < n; i--)
    printf("X");
    ๐Ÿ˜
  • Mahesh
    @mahesh-wLPhv2 • Oct 7, 2006
    third method:
    int i, n = 20;
    printf("X");
    How can this work? This is an infinite loop.
    @thebigk • Oct 7, 2006
    Maheshthird method:
    int i, n = 20;
    printf("X");
    Good Catch, Mahesh ๐Ÿ˜€ . Devi Prasad might want to fix it.
    -The Big K-
  • bantini
    @bantini-EVA22R • Oct 10, 2006
    how about (i=0;i<n:-i--)?๐Ÿ˜• hey dude,just a lame attempt from an amateur!!!dunno much about c anyway!
  • pradypop
    @pradypop-Draqkg • Oct 11, 2006
    Maheshthird method:
    int i, n = 20;
    printf("X");
    I don't think there's an infinite loop in the code. Infact, statements inside loop are not executed even once.
    n=20, i=20 at initilization and condition is i<n, 20<20 is not true. Condition fails straightaway.
  • Mahesh
    @mahesh-wLPhv2 • Oct 11, 2006
    Still the program is wrong.Can you give correct solution?
  • pradeep_agrawal
    @pradeep-agrawal-rhdX5z • Oct 18, 2006
    /* 1st Way: Change i in i-- by n*/
    int i, n = 20;
    printf("X");
    /* 2nd Way: Add - before i in i < n */
    int i, n = 20;
    printf("X");
    /* 3rd Way: Change < in i < n by + */
    int i, n = 20;
    printf("X");
  • Prasad Ajinkya
    @prasad-aSUfhP • Oct 18, 2006
    This is decent enough, hope the 3 ways are as follows -
    int i, n = 20;
    printf("X");
    int i, n = 20;
    for (i = 40; i < n; i--)
    printf("X");
    int i, n = 20;
    for (i = 0; i > n; i--)
    printf("X");
    I have indicated in red the change in character that I have made.
  • ksrbhanu
    @ksrbhanu-7vVvZL • Nov 2, 2006
    Hi friends,
    I have one method, i will try other two. mean while review this method
    int i, n = 20;
    printf("X");
    replacing the i in the decrement statement with n it works , this is one character change ๐Ÿ˜Ž
  • ksrbhanu
    sory guys, i have n't checked the whole chain , pradeep has already posted this metho ๐Ÿ˜”
  • spirit
    @spirit-C1iJsl • Nov 9, 2006
    hello.....i m giving your answer n u have to tell thats right or not.....๐Ÿ˜Ž
    this is your code........
    int i, n = 20;
    printf("X");
    1. instead of i-- in the loop,change it as n--.
    2.in initialisation,n=20,change it as:n=-20.
    3.instead of i--,use:i++.
    ๐Ÿ˜
  • rahul dev choud
    @rahul-dev-choud-qQtOsv • Jan 16, 2007
    hey its really interesting don't tell da ans...
    working on it ....
    w'll back soon......
