  • Morningdot Hablu
    @morningdot-6Xuj4M • Aug 2, 2010
    Ok i started with the first one.
    "cd ~/Desktop" command to access the desktop file through terminals
  • Morningdot Hablu
    @morningdot-6Xuj4M • Aug 3, 2010
    Many of our CEan facing problem in finding packages for installing any software.
    If you are new in ubuntu try to follow this for installing softwares "System->Administrator->synaptic package manager" or "Accessories->Ubuntu software centre".
    If you have more share with us.
  • Aashish Joshi
    @aashish-VrevFC • Aug 4, 2010
    Install compizconfig-settings-manager to have greater control over the Desktop Effects (using Compiz of course!! ๐Ÿ˜ )
    among others you can enable water effect which is basically like raindrops on your desktop!! Some of the effects are very cool!!
  • sushant005
    @sushant005-tyt4WK • Aug 13, 2010
    Install all required packages for c and c++ programs.Here is the command which install all the packages :sudo aptitude install build-essential.
    1>Write the program and save using .c(for c program) and .cpp(for c++ program).
    2>If you have save it to the desktop then write like this:-cd ~/Desktop
    3>now to compile write the following in the terminal:-g++ <your file name>.cpp -o <your file name>.----->for c++ program
    for c program write .c instead of .cpp and gcc instead of g++.
    4>to execute the program write:- ./<your file name> for ex ./hello.
    and you are done..
  • Leo
    Leo
    @leo-ZJQlmh • Aug 13, 2010
    Buddy i think you are starting very fast, many people are still new to Linux, start from basic.
  • sushant005
    I simply mention the command to install the required package for c or c++.
    I think being a computer science we have to know how to write and compile a simple program in operating system which we are using thats why i share this tips here
  • Special
    @special-bJB6Ij • Aug 14, 2010
    LeoBuddy i think you are starting very fast, many people are still new to Linux, start from basic.
    your are right
    please do start with the basic,
    i had installed ubuntu , i couldnt install anything in that.
    I coundnot even play my mp3 songs every time i have to convert the song into .ogg format and then play it๐Ÿ˜”
  • Morningdot Hablu
    @morningdot-6Xuj4M • Aug 14, 2010
    Specialyour are right
    Hey we started with the basics.Read from the 1st post.Here in ubuntu you need packages to installed any type of software.I think you need some mp3 player try to follow this "System->Administrator->synaptic package manager" or "Accessories->Ubuntu software centre" and search for the vlc.
    Let me know if any more problem is there.
    If you are new in ubuntu try to use some day after some day's you must like to work with them.I am realy a big fan of ubuntu.
  • Special
    @special-bJB6Ij • Aug 15, 2010
    can you tell me from were did u download ubuntu
  • Morningdot Hablu
    @morningdot-6Xuj4M • Aug 15, 2010
    Check out here #-Link-Snipped-# for desktop edition.
    You can also order for it you just have to do a registration.And they send you a original CD of ubuntu on your house.It's free because ubuntu is open source.
  • Special
    thanks buddy! i will first install it and then i will ask your help. last time it took 5hours for installation, i was really fed up of it, i will download it and work it on the vmware
    thanks!
  • Special
    mohit007kumar00Check out here #-Link-Snipped-# for desktop edition.
    i couldnot install ubuntu on vmware
    now can you tell me what to do?
  • bharathpb
    @bharathpb-FtEhYi • Aug 16, 2010
    Specialu...
    Let me know what error you got while installing ubuntu in vmware...?
  • Special
    @special-bJB6Ij • Aug 17, 2010
    bharathpbSpecialu...
    there was no error it just got stuck there
  • Morningdot Hablu
    @morningdot-6Xuj4M • Aug 17, 2010
    If you complete your downloading->write it in a CD->start your OS->insert your CD->and then installed it under your current OS.
  • Morningdot Hablu
    @morningdot-6Xuj4M • Aug 18, 2010
    Install Midori 0.2.7 in Ubuntu 10.04/9.10
    Midori is a lightweight web browser.
    Open your terminal and type this command "sudo apt-get install midori"
  • Morningdot Hablu
    Install Latest Version of shutter in Ubuntu 10.04/
    Shutter is a feature-rich screenshot program. U can take a scrnsht of a specific area, window,
    Open your terminal and type this command "sudo apt-get install shutter"
  • Aashish Joshi
    @aashish-VrevFC • Aug 21, 2010
    Speciali couldnot install ubuntu on vmware
    if you just want a feel of ubuntu in a virtual enviroment, i suggest you try Oracle's virtualbox. It is easy to use, the documentation is easy to understand. All you need is an .iso image on your computer you can install it from there.
  • Morningdot Hablu
    @morningdot-6Xuj4M • Aug 28, 2010
    Follow this to install GNU c++ compiler in ubuntu.
    System->Administration->Synaptic package Manager->quick search for g++ and apply for installation.
  • Special
    @special-bJB6Ij • Aug 31, 2010
    try installing wine software, it supports almost every .exe file
  • Special
    how to run java programs?? in ubuntu?
  • Morningdot Hablu
    @morningdot-6Xuj4M • Aug 31, 2010
    Search for JDK in Synaptic Package Manager and apply for downloading.
    After the installation open gpedit text editor write any program of java save them and try to compile and run from the terminal.
    let me know if any problem is there.
  • Special
    Am not able to run c programs in ubuntu,
    if i declare the header file conio.h it gives an error that "add.c:2:18: error: conio.h: No such file or directory"
  • Special
    Also am not able to run a simple program of addition,
    the program codes are:
    #include<stdio.h>
    void main()
    int a,b,c;
    scanf("enter the nos",&a,&b);
    c=a+b;
    printf("the sum is %d",c);
    the output given is:
    anupam@ubuntu:~$ gcc add.c -o add
    anupam@ubuntu:~$ ./add
    13 5
    the sum is 142898335anupam@ubuntu:~$
    please suggest something.....
  • Aashish Joshi
    @aashish-VrevFC • Sep 1, 2010
    conio.h is windows specific. use iostream instead
