Time bounded input in C programming language
Gaurav sharma
@gaurav-sharma-Fg87wo โ€ข Oct 22, 2024
๐Ÿ˜
I want to know about ๐Ÿ˜’ "time bounded input in c language" ...
it means user has only few seconds which has define by developer
if user is not give input on this time next line should be compile.
but note this this funda or logic should be in c language.....
  • niraj.kumar
    @nirajkumar-6nokRG • Sep 28, 2008
    You can use sleep() command to implement that .
    Or other way would be to use user defined signal handling
  • sriramchandrk
    @sriramchandrk-wt4rlR • Sep 29, 2008
    Use alarm command
    try to find in stevens book or google it.
    Regards
    Sriram
  • mahul
    @mahul-ZxpiLA • Sep 29, 2008
    One easy way is to fork a child process that will generate a signal after a fixed time. This signal when captured can be used to skip the line.
