the actual process of data recovery
lovejeet
@lovejeet-etHdkD โ€ข Oct 12, 2024
we rush for the data recovery as soon as some important files gets deleted up accidentally. but i wonder how the process of recovery actually works out. One thing i listened up is that when we delete the data, the pointers to the memory locations just clear up, not the data on those memory locations, so when we try to occur, it establishes back the pointers and data is recovered. Is this true?? n if yes, then still, HOW!!!
    @thebigk Apr 17, 2012
    When a file is 'visually deleted' from the computer; the operating system only removes the 'path' to that file. That means, all the ones and zeroes that made up the file are still there on the drive. The data recovery process involves identifying all those places where your original file was 'actually stored'.
    I think computer engineers will be able to answer your query in a much better way. ๐Ÿ˜€
    @anoop-kumar-GDGRCn Apr 17, 2012
    lovejeetOne thing i listened up is that when we delete the data, the pointers to the memory locations just clear up, not the data on those memory locations, so when we try to occur, it establishes back the pointers and data is recovered. Is this true?? n if yes, then still, HOW!!!
    yes , only the starting pointer will be deleted. but the whole data is still in disc.
    Its like a house is still there and address is removed from adress directory.Recovery softwares are able to link chunks of deleted files and recover them .
    Now recovery softwares are very optimized and can even recover files which got overwritten as HDD are magnetic disc and intensity of magnetic field help them to recover overwritten files.
    Don't know how SSD deals with recovery in overritten filesโ˜•
  • lovejeet
    @lovejeet-etHdkD Apr 18, 2012
    ya, but how do re locate back the pointers, that, is, to the starting pointer of the data chunk after being removed.
    @anoop-kumar-GDGRCn Apr 18, 2012
    See this ... #-Link-Snipped-#
    It will clarify you and you can experiment with it by manually deleting data and recovering them directly from address.๐Ÿ‘
  • PraveenKumar Purushothaman
    @praveenkumar-66Ze92 May 6, 2012
    ianoopSee this ... #-Link-Snipped-#
    Awesome information bro... Would try it out and share the experience! ๐Ÿ˜€
