TC in full screen on vista ultimate
hridesh007
@hridesh007-OtPPno โ€ข Oct 26, 2024
hello,,, ur thanks to take intrest in my prob...
can i run tc... in full screen on vista ultimate !
PLZ DO REPLY IT ...((i`m new user in c))
๐Ÿ˜›
  • sriramchandrk
    @sriramchandrk-wt4rlR • Sep 30, 2008
    1. Run tc in dos command prompt
    2. Then press Alt + Enter
    To return back again use Alt + Enter
    Thanks & Regards
    Sriram
  • anki_0305
    @anki-0305-290jhs • Sep 30, 2008
    you can't run tc in fullscreen mode in windows vista, this is a drawback of vista, but you can resize the window size of tc by changing the properties of tc window
  • crazypooh
    @crazypooh-M3Fsm5 • Oct 5, 2008
    yep u can run tc on full screen on vista provided by latest borland compiler.b happy
    @thebigk • Oct 5, 2008
    I REPEAT :
    Usage of SMS text is NOT allowed on CE Forums!
  • saurabh2486
    @saurabh2486-Tr6NOC • Aug 4, 2009
    yaaa u can of cours but it should be 32 bit not 64 bit
  • shashank734
    @shashank734-jxXXKs • Aug 4, 2009
    so i assume you have turbo c compiler in your vista machine.when you double click on tc.exe,you get the message as shown below.
    รขย€ยœthis system does not support fullscreen mode.choose close to terminate the applicationรขย€ย. now if you click ignore you will see a very small screen ,which wont help much in writing programs.
    how to run turbo c then?
    step 1: go and download dosbox software #-Link-Snipped-#. install the downloaded software.
    step 2:copy all your turboc files in one folder in c drive.i mean copy all the files in the bgi,include folders,and all other folders into a new folder.you should have all those files under a single folder.
    step 4: run dosbox
    step 5: at the prompt in dosbox window ,type รขย€ยœintro mountรขย€ย
    step 6: type mount c c:\tc ( if รขย€ยœtcรขย€ย is the nameof folder you copied all files of turbo c)
    step 7: type รขย€ยœc:รขย€ย
    step 8: type รขย€ยœdirรขย€ย™ in front of c:\ and type รขย€ยœtcรขย€ย
    that should be all.select ok at the prompts that pop-up .and the next time you start turboc from dosbox ,press alt+enter.
    happy programming.!
    • you cant use keyboard shortcuts like ctrl+f9 and others ,you will have to use mouse for that.
    • dont forget to clear the text under options>>directories in turboc before you compile the program.
    then you done..
  • shashank734
    you can also use devcpp
    this is also good compiler and freeware just find on google.....
  • mayjune
    @mayjune-L5ZVXc • Aug 8, 2009
    dosbox is the best way to do it
    A) It runs fullscreen
    B) It runs TC Graphics, which Vista doesnt support
    But if you are not doing this for college, i would recommend you do it using Code Blocks. Its a very good ansi c standard compiler...
  • sunit.soni
    @sunitsoni-iK2OBk • Sep 4, 2009
    shashank734so i assume you have turbo c compiler in your vista machine.when you double click on tc.exe,you get the message as shown below.
    step 4: run dosbox
    happy programming.!
    then you done..
    but its not including the header file and also showing error "unable to make output file"...??
  • shashank734
    @shashank734-jxXXKs • Sep 5, 2009
    sunit.sonibut its not including the header file and also showing error "unable to make output file"...??
    This works for me perfectly you should copy all files just check it.....
    but i personaly advise you to use devcpp it's a good compiler for c and c++....and has good features.. just google it it's..free
  • syntaxerr
    @syntaxerr-90idoj • Feb 21, 2010
    To run tc in full screen in vista:
    Lets assume your tc folder is in d drive.
    1)Install Dosbox.
    2)Run dosbox.
    **3)Type the following at the prompt.
    a)intro mount
    b)mount d d:\tc
    c)d:
    d)tc
    4)Press alt+Enter.
    5)Go to option->directories
    6)Change the first two rows to "include" and "lib" respectively.
    7)delete the third and forth row.
    Imp:
    a)To run your program you cant use ctrl+f9 as ctrl+f9 is the shortcut (of dosbox) to exit dosbox.
    b)You can use the other shortcuts.
    c)you have to perform steps 5 to 7 everytime you open tc from dosbox.
    To automatically open tc on startup of dosbox
    1)go to your dosbox folder.
    2)open the file dosbox.conf
    3)look for autoexec(it is at the end of the file)
    4)under that type the following
    intro mount
    mount d d:\tc
    d:
    tc
    5)next time whenever you will run dosbox tc will automatically open.
  • shalinishetty
    @shalinishetty-XIcSv1 • Apr 8, 2010
    hi i followed dis instruction i got full screen in windows vista....but after executing the program i am not able to get the output getting 2 errors for all programs...one is canot include stdio.h another is not terminated correctly...i dont have mouse...i could able to comile by touch screen...cntr f5 n alt f9.....i think same error ill get wen i use mouse.......i dont think ill get a diff wen i use mouse n touch screen...plz tell me wat may be the fault...actually i have saved in c directory...in dos box also i changed to c directory...i saved a prog as p.c den executed...same error...i saved as p.cpp also..actually how should i save.....?
  • shalinishetty
    Re: TC in full screen on vista ultimate
    1)Install Dosbox.
    2)Run dosbox.
    a)intro mount
    b)mount d d:\tc
    c)d:
    d)tc
    4)Press alt+Enter.
    Imp:
    intro mount
    mount d d:\tc
    d:
    tc
    5)next time whenever you will run dosbox tc will automatically open. โ€‹
  • Pensu
    @pensu-8tNeGU • Apr 8, 2010
    You cant run TC in full screen in windows vista.....in place of that you can use Dev C++..its also a good compiler....
  • shalinishetty
    @nicepeeyush but we can run it with dos box itseems...i got a fullscreen wen run with dosbox but i dont know still wat i hav to change?????????is dat bz of not using mouse????????/i am using touchscreen i am able to use cntr f5 n alt f9 den wats d use of using mouse?///////plz help me....k tell me how to execute a program in a DEV++
  • Pensu
    Well i dont know much about dos box....i will try it....but for Dev++ do the following:-
    For compilation - Ctrl+f9
    For execution - Ctrl+f10
  • gaurav.bhorkar
    @gauravbhorkar-Pf9kZD • Apr 8, 2010
    If anyone's finding Dosbox method difficult, then try this,
    1. Install #-Link-Snipped-#
    2. Then install windows xp OR 2000 in the virtual m/c
    3. Install TC in that windows
    and you are done. It's easy, I guess.
  • shalinishetty
    i executed the program...it is showing enter dos command...wat should i give...anothemess is it has not installed properley n no such files in a directory plz give d instuction clearly one after the other bz in dat there is a project something n all....i will be waiting for ur reply..
  • shalinishetty
    i have vista how i can i change to xp.....tell me how to execute tc in in vista itself
  • shalinishetty
    @shalinishetty-XIcSv1 • Apr 10, 2010
    oo
    HI friends it is very important instructions to run c program in ur dosbox.....i tried for one week by trying with the above tutorial....it might have helped many but i was struggling to execute by using dat instructions...any way thanks for them to put dat tutorial....here we have to make slight changes... follow it....
    1.first save tc file in c drive
    2.open dos box
    3.intro mount
    4.mount c c:\
    5.c:
    6.cd tc
    7.cd bin
    8.tc.exe
    den to get a big screen alt enter
    file new type a program wen u gve save as u ll get a new window der select ..\ den ull get BGI
    BIN
    EXAMPLES
    click on bin ull get something like C:\BIN\programname.c dats it ....if u hav vista in ur laptop u can surely get a big screen wen u use dosbox with dis instructions....den to use cntrl f9,,,,,, alt f5....happy programming...
