  • Suggest me a Laptop for the following needs
    Manish Goyal
    Manish Goyal
    @manish-r2Hoep
    Updated: Oct 26, 2024
    Views: 1.1K
    Hello Friends
    Kindly suggest me a laptop for following needs
    1:- Light weight : not more than 2 KG (Most important)
    2:- Screen Size: between 10 " - 14 "
    3:- Battery Back up (I should be able to travel for around 10 hrs and it should not require charger)
    4:- Hard disk storage ( 300 GB would be enough)
    5:- Ram 2 GB
    6:- Wi-fi , Bluetooth etc
    My Budget is 35k to 50 k
  • lovejeet
    MemberFeb 15, 2012
    suggested 1's are:
    #-Link-Snipped-# (dell)
    HP Pavilion DM4-1024TX
  • CE Designer
    MemberFeb 15, 2012
    I'd choose the dell.
    AdministratorFeb 15, 2012
    CE Designer
    Dell ain't no good for the battery life.
    If you can extend your budget by a few thousand; go with a Mac. I've always had great experience with the battery backup. But then, you'll be a bit limited by the choice of software.
    HP & SONY, I've heard, offer good battery backup. But please take another opinion before you decide on them.
  • born_star16
    MemberFeb 15, 2012
    I agree with Big_k😀 ...........I am also using Dell laptop and the battery is not very impressive at all. Better go for HP.
  • lovejeet
    MemberFeb 16, 2012
    and i guess hp and hcl gives better price value of their products than dell and other brands.
  • Dancer_Engineer
    MemberFeb 16, 2012
    My vote goes to HP as well. 👍
  • Manish Goyal
    MemberFeb 16, 2012
    The_Big_K
    I am also thinking of buying mac
    can you please tell me more about this?
    "you'll be a bit limited by the choice of software."
    AdministratorFeb 16, 2012
    goyal420
    Windows has several options for software. Can you elaborate a bit on your primary usage of the laptop and what software you'll need for your work?
  • ursplfrnd
    MemberFeb 16, 2012
    I would suggest you to select among Dell XPS series(15 or14z) and HP pavilion Dv6 series.
  • CE Designer
    MemberFeb 16, 2012
    If battery life is high on your list of criteria then you can always request a 9 cell battery. I have been using my dell 1520 for over 5 years now. After the first year i had to change my motherboard, but that was my fault. I used to run high graphic games for long periods of time and put it in my backpac right after. Poor ventilation caused it to sweat. But 4 years after i have used Solid Works on it, i still run many games, moves and sofware like Sony Vegas pro and others. I never had a problemm since. My sister had a Hp and well, so many complications to mention.
  • Manish Goyal
    MemberFeb 16, 2012
    The_Big_K
    I am a Web Developer
    So I will require installation of Software like putty, filezilla, tortoise, exlipse, git etc
    actually weight and battery back up is my primary consideration while buying laptop,
    For that I guess mac will be suitable for me but if i won't be able to use these software then it will be of no use to me
    goyal420
    Okay, that's cool. SSH client is inbuilt in Mac and Filezilla, Eclipse, GIT have their Mac presences.
    The biggest drawback of using Mac is the availability of word processor that competes with Microsoft Word. Even MS Word on Mac isn't as usable as its Windows counterpart.
    You might also need a code editor; and most of the 'good' ones on Mac are all paid. If you're going to develop for the Web; you'll always need a Windows machine to test your code on IE; I think simulators don't match up with the actual IE behavior on Windows.
    Where Mac excels is it's beautiful to use and macbooks have *long* battery life. Plus, they cost a bomb!
  • Sony support
    MemberMar 9, 2012
    Dear Goyal
    I would like you to have a look at vio series on Sony laptops. I am sure that they will satisfy all your needs for what you are looking for.
    Thanks and Regards
    Sony Support.
  • Abood_ajmal
    MemberMar 9, 2012
    goyal,According to me .i will suggest you to buy Thoshiba Satellite,
    you will like it
    AdministratorMar 9, 2012
    #-Link-Snipped-# I've been hearing about Toshiba Laptops from several people. How's the battery life and average battery life?
  • Abood_ajmal
    MemberMar 10, 2012
    The_Big_K
    Sir it is awesome laptop ,i usually use with battery in college only so i cant say exactly about battery life ,once i used continuously 3 to 4 hours AutoCad (half charge)
