  • Ashraf HZ
    @Ash • Jun 15, 2013
    Hi bro.. I usually use these two for networks & hardware comms:
    - PuTTY
    - Tera Term (v4)
    @thebigk • Jun 15, 2013
    PuTTy all the way. In fact, I tried to interview the creator of PuTTy on CE; but never heard back from him.
    Right now, I'm on OSX and the default Terminal is quite awesome.
    @harshad-ukH5ww • Jun 17, 2013
    ashHi bro.. I usually use these two for networks & hardware comms:
    - PuTTY
    - Tera Term (v4)
    I am using terminal mostly to receive data from UART. So I was looking for some terminal which are good in particular. I tried with Tera Term but it is not showing time-stamp for data received via COM port. Or may be I missed some configuration.
  • Manish Goyal
    @manish-r2Hoep • Jun 17, 2013
    git bash is also good
  • Ashraf HZ
    @Ash • Jun 17, 2013
    Harshad ItaliyaI tried with Tera Term but it is not showing time-stamp for data received via COM port. Or may be I missed some configuration.
    So far Tera Term can only display time stamps in the logs. You can enable this at the TERATERM.INI config file:
    ; timestamp flag for Log (on/off)
    LogTimestamp=on
    If you want to display at the display prompt, you'll need to play around with TTL scripting. It's not so straightforward, but TTL scripting is quite powerful to use for terminal functions: #-Link-Snipped-#
    I could probably try it out as well later this week when I'm free!
    goyal420git bash is also good
    Is it for Linux only? Will you please give me it's download link for windows if available?
    Seems it is open-source project.
  • Manish Goyal
    Git Bash is basically used code sub versioning, but I also use it to run linux commands on Windows
    <a href="https://git-scm.com/downloads" target="_blank" rel="nofollow noopener noreferrer">Git - Downloads</a>
    But I am not sure, if it will meet your requirements
