Bintee OP
@bintee-QkdTqJ • Feb 25, 2008
BinteeHey is there anyone hured about DRAFT -800?
its a new Steel Structure Code which is on "LIMIT STATE DESIGN".
Actually i have a problem in it.
so if anyone is there to know about DRAFT - 800 then reply so i can post my Problem here.
Thankswell thanks, i got solution of my question,
@thebigk • Feb 25, 2008
Binteewell thanks, i got solution of my question,
Bintee, how about sharing the solution with the rest of us? I guess it would help lot of engineers who're looking for the same.
Bintee OP
The_Big_KBintee, how about sharing the solution with the rest of us? I guess it would help lot of engineers who're looking for the same.
I m sorry, thanks for remind me.๐
Well i m doing dissertation n topic is on Draft โ 800, in which im doing Element design based on this code.
My prob was. โFor beam design there is Shear check and the condition is { Depth to thickness of web RATIO should be less then 67}, but if its not satisfy then we have to gone through CL:8.3 as per given in Draft โ 800, so there is a one equation in which I had needed to find YIELD STRENGTH OF WEB.
For that I gone through BS-5950-1 so I came to know that the value of โyield strength of web and flangeโ which is depend on thickness of thickest elements of the cross โ section, and in BS:5950-1 code the Table is directly given.(Ref. Pg. No. 63 and 25)
So I just want to know how we can determine value for same in our Draft โ 800, and the
SOLUTION : is given in same code SECTION โ 2, TABLE 2.1, Sl.NO.8.
THANK YOU๐
