Steel beams hold this countertop?
camar0
@camar0-zsQyhM โ€ข Oct 26, 2024
I have built an outdoor kitchen and trying to figure out if these beams will be sufice enough
these are 10' 9" beams with 7' 9" floating
2x2 14guage tubular stainless steel
a 24" wide 3cm granite top is planned sit on this
each side will have supporting 2x4 bases
from what i could find, granite is 18lb/sqft
with this are being approx 16sqft
weight is assumed to be then 288lbs ?
From what i could find only a 2x2 16guage has a beam load of 513 lbs
    @ramani-VR4O43 • Apr 17, 2018
    What extra load will come on the counter? If that is within another 250 lbs for the entire length of 7'9" and no additional dynamic load (like people climbing on top) this should perhaps work as the beam ends are supported 1'9" each side.
    How are the beam ends anchored?
  • camar0
    @camar0-zsQyhM • Apr 18, 2018
    Currently they are just sitting on 2x4... we were going to anchor them in with lag screws unless a better way?
    There should be no additional load on this countertop and it would just be for eating and entertaining.... no one should ever sit on this top
  • camar0
    btw the right side beam is only sitting on 3" of support , the left side has almost 32"
    @ramani-VR4O43 • Apr 18, 2018
    If there is a sag in the middle of the beams the granite slab may see a bending force acing on the middle. Being brittle it can crack. Grouting with a rtp silicone or epoxy between the granite and the beams will even out stresses.
    I am sure structural engineers on this site may come up with a better analysis.
