Steam Turbine Suppliers
Does anyone know of any good turbine suppliers for this application?
Thanks
Member • Apr 10, 2013
Member • Apr 13, 2013
Few hundred KW is not small. What kind of process is generating that kind of waste heat? Is flue gas the source of heat? Can you put up some more info on this source?Hugh HodkinsonThe application will be in the order of a few hundred kW. I've contacted several major suppliers, most of whom cannot help me.
did you contact Siemens?? they have that range availible .Hugh HodkinsonI'm looking at the possibility of reusing waste heat to generate steam and drive a turbine to generate electricity. The application will be in the order of a few hundred kW. I've contacted several major suppliers, most of whom cannot help me.
Thanks
Member • Apr 14, 2013
Member • Apr 29, 2013
The source is waste solvents which are being incinerated.A.V.RamaniFew hundred KW is not small. What kind of process is generating that kind of waste heat? Is flue gas the source of heat? Can you put up some more info on this source?
The Observerdid you contact Siemens?? they have that range availible .
Member • Apr 30, 2013
Member • May 5, 2013
Thats cool ! have a Happy working on ur task !Hugh HodkinsonI did and they provided a quote. Also Mechanology and Verdesis.
Member • May 12, 2013
Then what you should be looking for is a steam boiler that can use the waste solvent as fuel. The turbine is incidental once you have the steam.Hugh HodkinsonThe source is waste solvents which are being incinerated.
