Starter Motor Problem In Automobiles
ISHAN TOPRE
ISHAN TOPRE
@ishan-nohePN Oct 22, 2024
Here is a situation for mechanical engineers to solve. Rack your brains to showcase your engineering talent!
You are traveling with your girlfriend (Boyfriend if you are female) to some lonely countryside. You both are hungry and stop at some hotel. After your lunch, you as a driver try to start the vehicle but you are unable to do so. The problem is that, the starter motor of you car has failed. You have no help, and your girlfriend/ boy friend reminds you that you are a mechanical engineer.
Can you start your car and impress your partner?
P.S: Assume that you have all the tools and tool-kit with you.
  • zaveri
    zaveri
    @zaveri-5TD6Sk Aug 18, 2012
    do i have to start the car using the starter motor only.
    If no, then i will start the car by shifting it in first gear, and disengaging the clutch, and pushing the car from the back, and once the car has moved to a considerable distance, i will ask my girl to let go off the clutch.
  • zaveri
    zaveri
    But if the starter motor has to be used to start the car, and considering that the solenoid alone has failed. then all you got to do is bring the pinion gear of the motor manually in mesh with the flywheel gear, and then supply the power to the terminals of the motor, and once the engine roars into action, cut off the power supply and retrace the pinion gear manually.
    Is this right #-Link-Snipped-#
  • zaveri
    zaveri
    #-Link-Snipped-# #-Link-Snipped-# #-Link-Snipped-# #-Link-Snipped-# #-Link-Snipped-#
    What are your takes ?
    Ramani Aswath
    @ramani-VR4O43 Aug 18, 2012
    How about this? I used to start the petrol engine of the irrigation pump at my grandfather's farm like this:
  • zaveri
    zaveri
    @zaveri-5TD6Sk Aug 19, 2012
    bioramani
    I don't think the engines of today's cars are designed to accomodate hand crank levers. are they ?
  • white_hat
    white_hat
    @white-hat-RTFca6 Aug 21, 2012
    #-Link-Snipped-# ,Hand cranking is not an option without a decompression lever.(If you can hand crank a 3 or 4 cylinder car without decompression lever then it is the best way to impress your partner, because its next to impossible.)
    #-Link-Snipped-# ,Starter motor is situated under the engine, to get there you will have to jack-up front wheels.I don't think it can be manually engaged because pinion gear is secured inside the yoke.It is really time consuming work and your partner wont be impressed, waiting.
    I think the best option is to switch on the ignition, put the car into 2nd gear and push it from behind.After attaining a certain speed let your partner engage the clutch, while you keep on pushing.You will be out of there in no time.
    P.S:Its highly unlikely to find a hotel in a lonely country side, isn't it #-Link-Snipped-#?!
    Ramani Aswath
    @ramani-VR4O43 Aug 21, 2012
    P.S:Its highly unlikely to find a hotel in a lonely country side, isn't it @#-Link-Snipped-#?!
    Permanent resting places will be available though.
  • zaveri
    zaveri
    @zaveri-5TD6Sk Aug 22, 2012
    white_hat
    I thought so. the starter motor can be accessed only from below the car (i have noticed this in ford ikon). but #-Link-Snipped-# said that since you have the tools, you can still bring the pinion gear of the yoke using the screw driver as the lever. but that wouldn't help, because there wouldn't be much illumination below the car and you wouldn't know what you are doing.
    So thus the best method is to push the car.
  • ISHAN TOPRE
    ISHAN TOPRE
    @ishan-nohePN Aug 22, 2012
    #-Link-Snipped-#, it is rude to ask a girl a girl for help. So your answer in post #2 is wrong. Your answer in post # 3 may be considered. Simply what you need to do is, to use a jack so that your vehicle rests on 3 wheels and the fourth (one of the wheel to which the differential is connected, is in the air). Now start your engine in first gear. As the engine starts, make it in neutral. Now get down and remove the jack and enjoy the ride.
    bioramani
    Interesting to see such type of generator. I have seen a similar mechanism, with the help of a string, you start the motor.
  • zaveri
    zaveri
    Issue
    Rude to ask a girl for help ? hahaha .what if in the case the mechanical engineer is a girl ? (as you mentioned in your very first post)
  • ISHAN TOPRE
    ISHAN TOPRE
    zaveri
    My answer was only implied for your reply boy!😏
  • white_hat
    white_hat
    @white-hat-RTFca6 Aug 22, 2012
    Issue
    Oh you are right, I din't think about this!
    But on a second thought , what if its got automatic transmission , with a fluid coupling.In that case none of the above solution will work.How do you start such a car?
  • ISHAN TOPRE
    ISHAN TOPRE
    white_hat
    Sorry but I haven't thought about such a mechanism. Will need to look into it.
  • NAVATHE SACHIN
    NAVATHE SACHIN
    @navathe-8fNDWG Nov 16, 2012
    you are telling that start the engine in first gear.first of all how the engine is started?
