@yadavundertaker-0p3HBs • Nov 19, 2009
hi ..you can upload your figure by a simple procedure..
check this link ..
#-Link-Snipped-# -
@shubhrajeet-tiwa-HbUaIL • Nov 22, 2009
ATTENTION FOR MODRATOR:
i thought my thread was supposed to be in mechanical engg link
Update: Thread moved.
@civilprincess-308hDv • Nov 22, 2009
Hey buddy please try to avoid caps and bold while posting.... ๐
@civilprincess-308hDv • Nov 23, 2009
it might have been a mistake, they will try to rectify it and avoid showing your temper.....
@shubhrajeet-tiwa-HbUaIL • Nov 26, 2009
even after 6 day's no response from modrator about my complain.........
please any one solve that problem of F.M for me
@gohm-F3UUpP • Dec 9, 2009
This thread is more proper in this section as it does not pertain to mechanical engineering. Let's also please keep this thread on topic.
thanks, -
@madison49-fJmGSG • Jan 6, 2010
Re: 02 Solve low sync problem by lowering sync
After almost two years of a rock solid connection syncing at 12megs I recently started experiencing a ridiculous amount of drop outs. 02 asked me to carry out tests with their own router plugged into the test socket.
When this is done, I cannot use the service as all my machines are too far from the test socket and not wireless.
Two weeks of testing showing varied results - sometimes 24hrs with 5 drop outs, some times over 900. They set the sync speed at 7megs and 15dB which only gave one drop out.
Then I'm told that because this is stable, they are not sending out an engineer - this is solved.
_______________________________________________________________________________________
#-Link-Snipped-# | #-Link-Snipped-# | <a href="https://www.myatlantaplasticsurgeon.com" target="_blank" rel="nofollow noopener noreferrer">Plastic Surgeon Atlanta & Duluth GA | Cosmetic Surgery</a>
