Software for Heatloss Calculation Required
raj.tri
@rajtri-XLYCBH โ€ข Oct 27, 2024
I require a software for heatloss calculation and also to suggest me appropriate thickness of the insulating material to be used for Cold & Hot Thermal Insulation.
Please guide me through if anybody has these information.
Thanks in Advance
    @thebigk • Feb 2, 2009
    raj.triI require a software for heatloss calculation and also to suggest me appropriate thickness of the insulating material to be used for Cold & Hot Thermal Insulation.
    Thanks in Advance
    Have you tried searching in Google? I did and found following -
    <a href="https://www.google.com/#hl=en&q=software+for+heat+loss+calculation&btnG=Google+Search&aq=f&oq=software+for+heat+loss+calculation&fp=KxwsQBD4C84" target="_blank" rel="noopener noreferrer">Google</a>
    Does that help?
  • raj.tri
    raj.tri OP
    @rajtri-XLYCBH • Feb 5, 2009
    Thanks The Big_K but some of the software are confusing , i want some specfic links to tried & tested software.......
    @thebigk • Feb 5, 2009
    Raj.tri : To avoid repetitions, could you please tell us which software have you tried so far and found confusing?
