@sriramchandrk-wt4rlR • Oct 21, 2008
Methods are for Windows machines
1st method:
Try systeminfo command on command prompt.
It gives lots of information.
one line contains System Up Time
Example:
System Up Time: 2 Days, 1 Hours, 59 Minutes, 52 Seconds
2nd Method:
If you are on LAN then you could double click on connection status tray icon.
You can see Duration value which will be same as uptime. (this is only if you are on active network).
Methods for Unix machine
Use uptime command
Example:
$ uptime
10:22am up 2 day(s), 13:17, 3 users
Thanks & Regards
Sriram
