Simply supported, or fixed beam ?
zaveri
@zaveri-5TD6Sk โ€ข Oct 23, 2024
What kind of a beam is a ceiling joist ?
Obviously it sounds like fixed type. but last month i was going through a solid-mechanics text book, and it said that the type was simply supported.
  • Jeffrey Arulraj
    @jeffrey-xA7lUP • Sep 15, 2012
    what is a ceiling joist can any one post a picture of it
  • pikachu1994
    @pikachu1994-UcQIIJ • Sep 15, 2012
    jeffrey samuelwhat is a ceiling joist can any one post a picture of it
  • Jeffrey Arulraj
    from picture there is no point in concluding that this is a simply supported beam
    the true definition of fixed beam is that the beam is attached to the column by some binders like RCC and stuff
  • Saiwal
    @saiwal-NOzuWb • Sep 16, 2012
    the beam shown in the picture is a continuous beam. Simply supported and fixed beams are ideal cases which rarely exist in real world applications.
  • zaveri
    @zaveri-5TD6Sk • Sep 17, 2012
    let me tell you the difference between a fixed beam and a simply supported one;
    fixed beam: all degrees of freedom at the end points of this beam are arrested. in other words, the beam is stiffly fixed at both the ends.
    simply supported beam: degrees of freedom only along the y-direction is arrested. it can still move in the x and z-directions.
    now coming back to the ceiling joist, it appears to be fixed rigidly, so then how is it simply supported ?
  • Jeffrey Arulraj
    @jeffrey-xA7lUP • Sep 17, 2012
    it is continuously supported held there is provision either to fix it or let it be free
  • vamsi kancharla
    @vamsi-kancharla-kL9oxU • Oct 6, 2012
    zaveriWhat kind of a beam is a ceiling joist ?
    it is not simply supported it bears ceeling weight and transfers to ground through PILLARS or COLOUMNS
  • Jeffrey Arulraj
    @jeffrey-xA7lUP • Oct 6, 2012
    yup but we don't see any fixing of the beam to any of them they are placed on top of em with out being clamped tight
  • Mohamed Amir
    @mohamed-amir-GNsD1j • Nov 3, 2012
    it is partially not totally fixed.......
