Simple Puzzle on unequal weights.
You are given a weighing scale and 8 bags of rice. Seven bags are of equal weight. One is of a slightly heavier weight. You can compare the bags using the weighing scale. (note it doesn't give weight in kgs it gives just the comparison)
What is the minimum number of times you will have to perform a measurement on the weighing scale so that you can pinpoint the heavier bag.
Note :- 1) you can't use own hands to compare , the bag is heavier only slightly so only weighing scale can detect the difference.
2) weighing scale can hold an infinite weight on it.
Happy Puzzling. When you give answer , also show reasoning for benefit of others as is the custom of puzzles.๐
Many of you may have solved this one before in aptitude exams, it is common puzzle.
