simple password program problem in c++
sumit_goel
@sumit-goel-GHakPk โ€ข Oct 25, 2024
hello friends
i m beginners of c++ and i want to make simple password program that will accept password from user and simultaneously display the stars("*") with the simple while loop.
i have written the code of this program but this is showing wrong result.Pls help me in solving this problem.
The Code :
#include<iostream.h>
#include<conio.h>
void main()
clrscr();
char pwd[5];
int i=0;
while(i<5)
pwd[i]=getch();
cout<<"*";
++i;
cout<<pwd;
if (pwd=="sumit")
cout<<"correct password";
else
cout<<"wrong password";
getch();
  • Manish Goyal
    @manish-r2Hoep • Jun 2, 2010
    try this code if you find difficulty in understanding this code
    then post it here
    #include<conio.h>
    int check(char a[],char b[]);
    void main()
    clrscr();
    char pwd[5],def[]="sumit";
    int i=0,mycheck;
    cout<<"Please enter password:-";
    while(i<5)
    pwd[i]=getch();
    cout<<"*";
    ++i;
    cout<<endl;
    mycheck=check(pwd,def);
    if (mycheck==1)
    cout<<"correct password"<<endl;
    else
    cout<<"wrong password"<<endl;
    getch();
    int check(char a[5],char b[5])
    {int i;
        for(i=0;i<5;i++)
            if(a[i]!=b[i])
            break;
        if(i==5)
        return 1;
        else
        return 0;
  • gaurav.bhorkar
    @gauravbhorkar-Pf9kZD • Jun 2, 2010
    sumit_goelhello friends
    The Code :
    Your code:
    #include<conio.h>
    void main()
    clrscr();
    char pwd[5]; [COLOR=Blue]// This should be of length 6, "sumit" measures 5 but one extra for '\0'[/COLOR]
    int i=0;
    while(i<5)
    pwd[i]=getch(); [COLOR=Blue]/* There is no equivalent for getch() in std C++. you have to compile this as a C program */[/COLOR]
    cout<<"*";
    ++i;
    cout<<pwd; [COLOR=Blue]//Why are you printing the password. Here you should print a new line.[/COLOR]
    if (pwd=="sumit") [COLOR=Blue]// This will not work in a C program, use strcmp ().[/COLOR]
    else
    getch();
    Here is my C equivalent. I used C because I wanted to use getch () which we cannot use in C++. Moreover, there is no equivalent function to getch () in C++.
    What getch () does is, taking a single keystroke as input. I tried using cin.get () in C++ which is equivalent to getchar() in C which takes a keystroke but waits for the Enter key.
    So, here is the C code,
    #include<stdio.h>
    #include <stdlib.h>
    #include <conio.h>
    #include <string.h>
    int main()
    system ("cls"); /[COLOR=Blue]/ clrscr () equivalent[/COLOR]
    char pwd[6]; [COLOR=Blue]// as i said, length should be 6 to accommodate the null character.[/COLOR]
    int i=0;
    while(i<5) [COLOR=Blue]//because the string is of length 5[/COLOR]
    pwd[i]= getch ();
    printf ("*");
    ++i;
    pwd[5] = '\0';[COLOR=Blue] // Null character which signifies the end of string.[/COLOR]
    printf ("\n");
    if (!strcmp (pwd, "sumit")) [COLOR=Blue]/* strcmp returns 0 if the strings are identical, hence the !
    operator, ie. the NOT logical operator. (so 0 becomes 1 i.e. True) */[/COLOR]
    printf ("correct password\n");
    else
    printf ("wrong password\n");
    system ("pause");[COLOR=Blue] // getch ()[/COLOR]
    I hope you get it.
  • gaurav.bhorkar
    @goyal420, which compiler did you use? Your program isn't compiling in VC++.
  • Manish Goyal
    @manish-r2Hoep • Jun 3, 2010
    I don't agree with this statement .YES we can use this function
    It is available in conio.h file
    Borland C++ Compiler 5.5
    Is it really necessary to take extra memory for null character also ????
    I mean can't you take char pwd[5]; only
  • Morningdot Hablu
    @morningdot-6Xuj4M • Jun 3, 2010
    hello guy's
    up to what i know getch() is not an c or c++ function.
    it is a compiler extension. you can use it in either c or c++ if your compiler support it.
    @ goyal
    @gaurav
    here the header taken by you guy's are not standard(ANSI standered).
    <iostream> is standard, <iostream.h> is not
    >getch() is still available int the conio.h header file (at least in MinGW).
    I'm sure it works just fine on your compiler, but because it's non-standard, that means it's not guaranteed to work on my compiler, or someone else's compiler.
  • gaurav.bhorkar
    @gauravbhorkar-Pf9kZD • Jun 3, 2010
    goyal420Is it really necessary to take extra memory for null character also ????
    Going by your program, taking pwd[5] works perfectly, because you have checked each and every character in check() function.
    But according to the definition of a string, the last character is the '\0' null character. It is required because the compiler (or std lib functions) should know where the string ends.
    Regarding the conio.h file, it is a non standard file written by Borland for use in Turbo C compilers. The modern compilers like GCC and VC++ doesn't support it. Try it, VC++ says, "cannot find conio.h".
  • gaurav.bhorkar
    mohit007kumar00hello guy's
    @ goyal
    @gaurav
    According to standard C++, <iostream.h> is not correct (but works), it should be <iostrean>.
    I've used C, so in C you have to write <stdio.h>. The extension .h is necessary.
    @goyal420: You program will definitely work in Turbo C/C++ compilers. No offense meant, your program is written in C++, but with a C accent. According to modern standards, main () in C++ should always return an int. You haven't used the namespace std. Thats why it is not working in VC++.
  • ankesh.cs2007
    @ankeshcs2007-GnaFEW • Jun 7, 2010
    i agree with gaurav bhorkar
  • vignesh kumar selvakumar
    @vignesh-kumar-selvakumar-W54SsB • Apr 9, 2015
    #-Link-Snipped-# the password program is not working , in pwd some junk value is getting stored , pls help.
  • Vishal Sharma
    @vishal-pysGmK • Apr 9, 2015
    The Code :
    #include<conio.h>
    void main()
    clrscr();
    char pwd[5];
    int i=0;
    while(i<5)
    pwd[i]=getch();
    cout<<"*";
    ++i;
    cout<<pwd;
    if (pwd=="sumit")
    else
    getch();
    I wrote this code, kinda long back when I was new at CE. It's simple and written in C, shouldn't be much problem for you to convert that in C++. After all, there's some work even you should do instead of a simple copy paste ๐Ÿ˜€
    #include<stdio.h>
    #include<conio.h>
    int main() {
        char pwd[50],c;
        int i = 0, done=0;
        while(!done) {
            c = getch();
            switch(c) {
                case '\r':
                    pwd[i] = '\0';
                    done = 1;
                    break;
                case '\b':
                    i--;
                    fputs("\b \b",stdout);
                    break;
                default:
                    pwd[i++] = c;
                    putchar('*');
        putchar('\n');
        fputs(pwd,stdout);
  • Vishal Sharma
    oh, my bad! didn't notice how old this post is
  • mohit gahlot
    @mohit-gahlot-lOlHSC • Feb 1, 2016
    #include<iostream>
    #include<conio.h>
    #include<string.h>
    using namespace std;
    int main()
    string password;
    char ch[10];
    int k=0;
    cout<<"Enter password\n";
    ch[k]=_getch();
    while(ch[k]!=13)
    if(ch[k]!=8)
    cout<<"*";
    k++;
    else
    k--;
    cout<<"\b \b";
    ch[k]=_getch();
    for(int i=0;i<k;i++)
    password.push_back(ch);
    // Try this, it is simple and easy
  • rambaburai911
    @rambaburai911-5ggEEU • Jan 16, 2017
    #include<conio.h>
    #include<string.h>
    void main()
    clrscr();
    char *a,*b="ramramram";
    int I,r=0;
    ram :
    cout<<"enter your password:";
    for(I=0;l<9;l++)
    a=getch();
    cout<<"*";
    r=strcmp(a,b);
    if(r==0)
    else
    {cout<<"incorrect password:";
    goto ram;}
    getch();
  • rambaburai911
    Hii I am a student of class12 science
    rambaburai911#include<iostream.h>
    #include<conio.h>
    #include<string.h>
    void main()
    clrscr();
    int I,r=0;
    ram :
    for(I=0;l<9;l++)
    a=getch();
    cout<<"*";
    r=strcmp(a,b);
    if(r==0)
    else
    goto ram;}
    getch();
    }[/QUOTEI]
