sensor operation
radha gogia
radha gogia
@radha-BTDzli Oct 23, 2024
I just wanted to ask that can i operate a camera based sensor through a wifi signal ,but the problem is that the wifi signal is not so strong,so can I operate my sensor..
  • Jeffrey Arulraj
    Jeffrey Arulraj
    @jeffrey-xA7lUP Oct 13, 2014
    Camera based Sensor first what is that?
    Next Wifi is not strong. What router are you using and what is the range of the repeater/ router you have used?
  • radha gogia
    radha gogia
    @radha-BTDzli Oct 13, 2014
    Jeffrey Samuel
    means it will be just capturing faces of different people
  • Jeffrey Arulraj
    Jeffrey Arulraj
    I am little confused.
    You are using a camera to capture image or a face of a person and then transmit the same to a computer using Wifi am I correct.
    If this is the case, Just check the range of the wifi router you are planing to use to connect the camera and the computer.
