@thebigk • Mar 3, 2009
Could you tell us about the Robosoccer project? Do you have any specific questions?
kewlsarkar OP
@kewlsarkar-YquTqz • Mar 3, 2009
Thanks for noticing my post.
robosoccer is a project in which a robot is intellegent enough to play football on its own.
It has to identify obstacles and oppostite teammembers and avoid them and identify ball to hit it and take it to the goal.
It will have application of image processing .
I have started working on Image processing using matlab , but its too basic, and i am getting no idea how to head for the project.
It will be great if iget a overview and kind of guidance for the project. -
@gohm-F3UUpP • Mar 4, 2009
I assume this is real and not virtual? soccer ball could have a frequency transmitter the robots pick up. GPS and sensors would locate the goal and other bots.
@silverscorpion-iJKtdQ • Mar 4, 2009
Rather than using sensors and GPS, you can use image processing to do it. But this still requires the use of AI. It's a complex project, but you can do it.
The robotics team of Carnegie Mellon University did a project in this and it was a huge success. now they are conducting world automatic robosoccer competitions.
You can search youtube to find plenty of videos about it. Also take a look at CMU website. There are some material available. -
kewlsarkar OP
@kewlsarkar-YquTqz • Mar 4, 2009
No, No gps is to be used.
ball is a simple ball , the robot has to identify it using image processing , and then take it to the goal , again identifying the right goal , and also avoiding contact with enemy team robots. -
@just2rock-DkmPtO • Mar 4, 2009
true ,image processing & also graphic analysis is required.For avoiding oppponent similar face recognision or colour recognizition is required.
Thanks,
J2R -
@Ash • Mar 4, 2009
How big is the playing field? One common method is to use a webcam hoisted at the top, and is able to see the whole field. The ball would be one specific colour, the goals another, as well as the players. This 2D view is sufficient.
kewlsarkar OP
@kewlsarkar-YquTqz • Mar 5, 2009
Ya, ash you are absolutely right.Field size is of less importance and that can be dealt with later.The remaining details given by you are very true.The cam will be either mounted on top or on the robot . It will take 2D pictures , send it to computer where code will be run, which will then send control signals to robot , and robot will move and act accordingly on the field. This is what is to happen.
My problem is this coding part. Can anyone anyhow help me in this ?????? -
kewlsarkar OP
either post it here or if possible send the details and related data to
Thanks in advance
๐
I luv CE -
kewlsarkar OP
this link i got from a student of CMU...
its really usefull. -
kewlsarkar OP
@kewlsarkar-YquTqz • Mar 8, 2009
Friends please keep flooding this forum with views ...
kewlsarkar OP
@kewlsarkar-YquTqz • Mar 27, 2009
kewlsarkar OP
