  • RFM70 - how to write code for the RFM70
    Futterama
    Member
    Updated: Oct 26, 2024
    Views: 1.3K
    Hi forum,
    The RFM70 (and the newer RFM73) from HopeRF is a cheap and powerful 2.4GHz transceiver that I use in some of my projects.
    Unfortunately the documentation from HopeRF is not the best, many things are missing in the datasheet and some things I have found to be actually misinforming.
    The sample code from HopeRF is kinda OK but even the code is not consistent with the info in the datasheet.
    Godfather helped me with some things I was struggling with and suggested me to post my trial-and-error findings here for others to use.
    I myself use Microchip PIC devices and the CCS compiler.
    Here are the first notes, more will be added later.
    NOTES
    - Only change mode between RX and TX (set/clear the PRIM_RX bit) while CE is low.
    - In TX mode, set CE high AFTER the payload has been loaded in the TX FIFO.
    HOWTO
    Transmit a package (no auto acknowledge):
    1. CE must be low.
    2. Clear the PRIM_RX bit to enable TX mode.
    3. Put payload in TX FIFO.
    4. Set CE high.
    5. Wait for IRQ.
    6. Clear the TX_DS bit.
    7. Set CE low.
    Great work buddy. 😀 This may be useful for those who are starting with RFM70.
  • vishal131291
    MemberOct 3, 2014
    I m not able to receive the data. Please help me to sort this problem.
    vishal131291
    Sure #-Link-Snipped-#,
    Will you please share some information about your hardware please and also some more detail about what exact issue you have in reception?
  • vishal131291
    MemberOct 3, 2014
    I m using atmega2560 for tx and i m getting tx status flag set.
    And on rx site i m using atmega32 but i m not getting CD i.e carrier detect flag.
  • vishal131291
    MemberOct 3, 2014
    i m sending my code.Please go through it.
    vishal131291
    I would like know few things before I go by code in detail. Are you able to read and write RFM70 register in Atmega32?
  • vishal131291
    MemberOct 4, 2014
    Yes .because now I m getting CD bit set but while reading payload, feedback from device is 0x00.
    If possible pleas check my code and suggest any changes I need to do in my code
  • vishal131291
    MemberOct 5, 2014
    This is my tx code.
  • vishal131291
    MemberOct 6, 2014
    If possible please send register configuration for rx side
