  • Replace the Question Mark with Appropriate Letter - Puzzle
    @abrakadabra
    Updated: Oct 27, 2024
    Views: 2.4K
    This is the first puzzle -
    Screen shot 2012-06-03 at 5.20.38 PM
    Also support you answer with appropriate reasons.
  • Dilip jain
    MemberJun 3, 2012
    o.............that pattern now if a is 1 then d is 3 units away from a ,.similarly you go backward .3units from end is w..........g-6units from front ....t 6units from rear........
    So as l is 11 units..o is 11 units from rear
  • Antoinette Jerom
    MemberJun 3, 2012
    The answer is letter O
    The alphabet is split into 2, groups of 13 each.
    A B C D E F G H I J K L M
    N O P Q R S T U V W X Y Z
    The first letter of the first group is mapped to the last letter with the second group and done accordingly to all the letters.
    Therefore, C (3rd Letter) mapped to X (3rd last letter).
    M (last letter) mapped to N (first letter).
    Hope its correct... 😘
    AdministratorJun 3, 2012
    #-Link-Snipped-# #-Link-Snipped-# Bingo! Correct Answer.
    In each segment of the diagram are a pair of letters, one of which is the same distance from the start of the alphabet as the other is from the end.
    Here is the next one: Which one of the five segments will fill the black gap?
    Screen shot 2012-06-03 at 8.59.27 PM
  • Antoinette Jerom
    MemberJun 3, 2012
    That'd be #1
    All those attempting the 2nd question should supplement their answers with apt reasons.
  • Drashan B Patel
    MemberJun 3, 2012
    obvious 1st one bcs as u go downwards gap of 2 alphabets are there thus in the 5th column after L, O must come...
    Correct Answer!
    Start at the top left and move down, then along one space to the right and up the next column, in a snakes and ladders pattern. Letters are written in alternate squares, in steps of 2 letters at a time.
    Here is the next one -
    Screen shot 2012-06-04 at 10.29.11 AM
    which letter should replace this question mark?
  • Prashanth_p@cchi
    MemberJun 3, 2012
    That should be 'B'.
    Considering all alphabets in their numeric order (A-1,B-2.....).
    Adding up vertically, 1st column yields 20, 2nd column 21.. So, last column should add up to 27, and hence B.
    Is it right #-Link-Snipped-#?
    AdministratorJun 11, 2012
    Yep. B is the right answer. 👍 You guys are completely awesome! We should keep sharing more puzzles.
