  • friendster7
    @friendster7-oVJr9h • Mar 22, 2008
    TEMPLATES IN C++
    INTRODUCTION
    Before I start this tutorial I assume that you have a Working Knowledge of OOP in C++. Without this, the tutorial will be of no use to you.
    This tutorial shows you how to Reuse Code, Save Typing Time, Prevent Time Spent on
    Debugging and saving source-code space.
    OK.Let me take a common example. The gr8 min() function returns the value which
    is lowest from the given two arguments.I shall show two examples now.One without
    Templates and one with Templates.Here is the first program.
     [quote]#include <iostream>
    using namespace std;
    int min(int a,int b)
      return (a < b)?a:b;
    float min(float a,float b)
      return (a < b)?a:b;
    char min(char a,char b)
      return (a < b)?a:b;
    int main()
     int a=10,b=5;
     cout<<min(a,b)<<'\n';
     char p='A',q='Z';
     cout<<min(p,q)<<'\n';
     float z=1.91f,x=3.98f;
     cout<<min(z,x)<<'\n';
     return 0;
    OUTPUT:
    5
    A
    1.91
    [/quote]
    Function Overloading doesn't help much as far as typing time and source space isconcerned.Also if you find an error in one such function,you have to correct it in all the other functions as well.With Templates all the work becomes a lot easier.Let's see the Templated Version now...
     #include <iostream>
    template <class T>
    T min(T a,T b)
      return (a < b)?a:b;
    int main()
     int a=10,b=5;
     char p='A',q='Z';
     float z=1.91,x=3.98;
     return 0;
    Same Output.Nearly the same Executable size.But what we have achieved is that
    the time we take to type the code is reduced.The code looks more readable and
    incase there is an error just correcting it here will make the change for all
    data types accessing this function.
    Let me explain what happens at compile time.When the Function us first called
    with this:
    cout<<min(a,b); //a and b are int's
    It goes to the function min(). Now T is the value that will be substituted with
    the data type of the parameter.So here T will be int.So Dynamically the Function
    Declaration becomes like this...
    In the second case T takes the form of a char and so on...The Compiler on every
    call still has to generate seperate functions for each data type but what we are
    saving are typing time and debugging ease.
    Some of you might wonder....what if we want all data-types to access a templated
    function except one? Like for example in a abs() function we would like all data
    types to access it except a char data-type.What do we do then?Well in such a
    case we override the function call like this...
     template <class T>
    int abs(T no)
      return (no<0)?(no*-1):no;
    void abs(char a){}
    This way even if accidentally a char data type is used as a parameter to the abs
    function..the overloaded function gets called...not the Templated version.
    What if we wanted a multi-parametered Templated Function? Here is the Syntax
     template <class T,class Q>
    void function(T item,Q data){}
    You now know enough of Function Templates.Now it's time to move onto Class
    Templates.
    OK.Now let us assume that we have a Stack class(Data Structure) that is capable
    of storing only int's. Now suppose you want it to store float's as well.You
    would normally write the whole class again by Copy/Pasting the Previous class
    and make the necessary Changes.But hey,There is a much better alternative.Using
    templates, you can manage just one class that handles different data-types.That
    way even if you find an error in your class,fixing it will make changes to all
    the data-types. Here is an example of a templated stack data structure.
     #include <dos.h>           // For sleep()
    #include <iostream>     // For I/0
    #include <windows.h>     // FOR MessageBox() API
    #include <conio.h>
    #define MAX 10        // MAXIMUM STACK CONTENT
    template <class T>    // Using Templates so that any type of data can be
               // stored in Stack without multiple defination of class
    class stack
      protected:
      T arr[MAX];       // Contains all the Data
      public:
        T item,r;
        int top;        //Contains location of Topmost Data pushed onto Stack
     stack()         //Constructor
      for(int i=0;i<MAX;i++)
      arr[i]=NULL;             //Initialises all Stack Contents to NULL
      top=-1;      //Sets the Top Location to -1 indicating an empty stack
    void push(T a)  // Push ie. Add Value Function
    top++;        // increment to by 1
    if(top<MAX)
    arr[top]=a;          //If Stack is Vacant store Value in Array
     else    // Bug the User
    MessageBox(0,"STACK IS FULL","STACK WARNING!",MB_ICONSTOP);
    top--;
    T pop()                  // Delete Item. Returns the deleted item
    if(top==-1)
    MessageBox(0,"STACK IS EMPTY\n","WARNING",MB_ICONSTOP);
    return NULL;
    else
    T data=arr[top];     //Set Topmost Value in data
    arr[top]=NULL;       //Set Original Location to NULL
    top--;               // Decrement top by 1
    return data;         // Return deleted item
    int main()
     stack <int>a;    // Create object of class a with int Template
     int opt=1;
     while (opt!=3)
     //clrscr();
     cout<<" MAX STACK CAPACITY="<<((MAX-a.top)-1)<<"\n\n\n\n";
     cout<<"1) Push Item\n";
     cout<<"2) Pop Item\n";
     cout<<"3) Exit\n\n";
     cout<<"Option?";
     cin>>opt;
     switch(opt)
      case 1:
      cout<<"Which Number should be pushed?";
      cin>>a.item;
      a.push(a.item);
      break;
      case 2:
      a.r=a.pop();
      cout<<"Item popped from Stack is:"<<a.r<<endl;
      //sleep(2);
      break;
     return 0;
    Everything looks similiar except an object declaration
    stack <int> s1;
    means that the value T is substituted by int. User-Defined Data Types
    can also be used provided the required overloaded operator functions are
    present.
    In case if we define the class functions outside the templated class,the
    syntax changes a bit.For a Constructor:
             template <class T>
            stack <T>::stack()
            //Code
    Yes,we have to define that template thing everytime we write a function
    outside the class.But if a function returns an object of the same
    templated class the syntax would be like this:
             stack <T> stack <T>::func(int data)
            //code
    Templates can also have pre-defined values like this:
             template <class T,const int max=10>
            class stack
              private:
              T data[max];
              //rest of the members...
    Templates can be inherited as well like this:
             class newstack:public stack<T>
             //members...
    That's all about templates.If you use Templates Frequently you will save
    a lot of typing and debugging time.
  • salaikumar
    @salaikumar-4lH6Nv • Apr 11, 2008
    hi my dear friend it is nice and useful for me.thank a lot.hate's of to u .
