reduction gearbox design
joe3204
@joe3204-0AY1KR โ€ข Oct 26, 2024
i have to design a 2 stage reduction gearbox. helical gear to be used in the first stage and spur to be used in the second stage....
i need names of books which will help in doing the same. i have to design the gearbox and select the materials and everything..URGENT..
thanks in advance,
joe
  • krishnamachari
    @krishnamachari-p67MeA • May 12, 2008
    use design data book for select the gear material, the teeth on gears are depends up on the design
  • joe3204
    @joe3204-0AY1KR • May 12, 2008
    thanks but i've already submitted my design...
  • gdh_ntsh
    @gdh-ntsh-xT3C88 • Jan 20, 2010
    hey, i have the same problem. i need to design a two stage reduction gear box with a ratio of atleast 10:1. the first stage has to be using helical gears, and second using spur gears. I need to decide the application, the material, size, module etc and calculate max load sustainable by the gearbox. i was thinking about grinding mills, but im not sure whether it requires a two stage gb or not. can anyone help me out?
  • Vega
    @vega-Ic42ds • Jan 20, 2010
    We will help you here. You can refer Machine Design by B. U. Bhandari
  • gdh_ntsh
    B.U bhandari or V.B bhandari? i have machine design by V.B, but it doesnt have what i need. I failed to find an ebook on B.U, could you ple provide a link? thanx
  • Vega
    huh, I am sorry. Then it might be what you said. I am getting too old to remember.
    ๐Ÿ˜€
  • gdh_ntsh
    thanx neway, i did some research and i think i will go with wind turbine gear box. It seems pretty straight forward and satisfies my conditions.
  • juma1987
    @juma1987-ukh0ej • Jan 20, 2010
    You can try Virgil M. Faires or Robert C. Juvinall, i personally prefer Juvinall
  • kriakkk
    @kriakkk-qI7yfq • May 21, 2011
    gdh_ntshthanx neway, i did some research and i think i will go with wind turbine gear box. It seems pretty straight forward and satisfies my conditions.
    hi, may i know for wt application u need a gear box of gear ratio 1:10
