@thebigk • Jul 24, 2008
Sure, tell us what problems are you facing?
@mayur-ywQKfu • Jul 24, 2008
Can you share more details about your project?
@momin-Jc6Ioa • Aug 22, 2008
such a project could be implemented in many different ways, u can use microcontrollers, microprocessor with aid of 8059 chip, or u can use simple logic gates with relays. u should specify ur level of implementation and then state ur problem clearly
@roshni0802-ar74hh • Oct 21, 2010
mominsuch a project could be implemented in many different ways, u can use microcontrollers, microprocessor with aid of 8059 chip, or u can use simple logic gates with relays. u should specify ur level of implementation and then state ur problem clearly
i need using simple logic gates and relays
