progressions
hiiiiii friends.... i have 1 sum... as i got the answer 3 bt the actual answeris 8 .
as the question follows.....
q: the angles of a polygon are in arithmetic progression .if the smallest angle is 100 degrees and the common difference is 10 degrees,then how many sides does the polygon have?
as i had done in the following way....
in A.P sum on n terms is n/2[2a+(n-1)d] as the first term is the least term a=100 d=10
as in polygon .....sum of the angles =360 as i substituted i got n=3....
is it not the correct way?
