Problems Adding values into an MS SQL table Via VB.Net
Hi all,
I had originally installed MS SQL Server 2008 R2 in my C: when I was developing the application. While I had the SQL DErver in my C:, everything was fine, no problems at all. Then I began getting low disc space messages, so I uninstalled it from my C: and Installed it in a new external hard drive. But then I started having problems adding values in on field of a table.
SPECIFICS:
The application in concern is an application that has a table named Users that is the cause of my trouble. It has 3 fields, of which the application can update 2 faultlessly. It's a field called Access_Level that is having trouble getting valuse added to it. Whatever choice I enter in the form, the field only gets "0" as the value, which is not even in the list of choices! I would welcome help on determining why this happens, and how to get the table to take the value I want it to!!
CODE SNIPPETS:
FORM:
    Public Class AddUser
    Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
    Dim Acc_Lvl, done As Integer
    Dim user, passwd, var As String
    passwd = ""
    user = NameBox.Text
    If (String.Compare(PassBox.Text, PassBox2.Text)) = 0 Then
    passwd = PassBox.Text
    var = ListBox1.SelectedItem
    Select Case var
    Case "Level 1 ( ACCESS EVERYTHING)"
    Acc_Lvl = 1
    Case "Level 2 (CAN NOT ADD AND DELETE USER)"
    Acc_Lvl = 2
    Case "Level3 (CAN ONLY USE THE ORDERS PAGE AND VIEW THE BILLS)"
    Acc_Lvl = 3
    End Select
    done = AddUserFun(user, passwd, Acc_Lvl)
    If (done = 1) Then
    MsgBox("User creation encountered an error")
    Else
    MsgBox("User Created")
    End If
    Else
    MsgBox("Password and Re Enter password fields don't match")
    End If
    End Sub
    Private Sub Button2_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button2.Click
    Me.Hide()
    Opening_Form.Show()
    End Sub
    End Class
AddUserFun Function:
Function AddUserFun(ByVal user, ByVal pass, ByVal acclvl) As Integer
Dim i As Integer
Try
Dim conn As New SqlClient.SqlConnection("server=THE-507FC9ABDEB;uid=indrajeet6;pwd=Indrani7&;database=VBDB")
Dim addusr As New SqlClient.SqlCommand
addusr.CommandText = "INSERT INTO dbo.Users VALUES('" & user & "','" & pass & "','" & acclvl & "')"
addusr.CommandType = CommandType.Text
addusr.Connection = conn
conn.Open()
addusr.ExecuteNonQuery()
conn.Close()
Catch ex As Exception
MsgBox(ex.Message)
i = 1
End Try
i = 0
Return i
End Function
I have the SQL Generated Script fo the database generation also, if needed. The basic thing is that the table is defined As Follows:
    CREATE TABLE [dbo].[Users](
    [Username] [varchar](50) NOT NULL,
    [Password] [varchar](50) NOT NULL,
    [Access_Level] [int] NOT NULL
    ) ON [PRIMARY]
    GO
  • Indrajeet Roy
    @indrajeet-w9OkQg Nov 4, 2012
    Any one? Please? This is an important question I need the answer to.
  • Indrajeet Roy
    Hi Reverend Jim and Icone, I solved the problem. The issue was a basic lack of understanding the difference between the ListBox ( What I had Used ) and a Drop Box (What I intended to use). What was happening was that I'd set the size of the list box to show only one item. I would Navigate to the Access Level I wanted by the scrolling Arrows, but not select anything, believing that since it was showing, I'd selected it. It was resolved by way of the following #-Link-Snipped-#. Check it out, all you VB.Net wannabe's!! (That includes me as a wannabe too!)😁
    Thanks for your help guys, and I will have to make it that if the user makes this kind of error, the error is caught and explained to the user!
