Problem with Windows XP Service pack 2
loraandbush
@loraandbush-Eqk5DF Oct 27, 2024
Service packe 2 is insatalled in my system , xp but when i run softwares which need sp2 , a error message comes that , you should install sp2 to continue.
  • Prasad Ajinkya
    @prasad-aSUfhP Apr 14, 2008
    There are two different versions of SP2 around, one was a pre-final release, a beta of sorts. If you have got that, then strongly suggest to upgrade to the later.
  • Ashraf HZ
    @Ash Apr 15, 2008
    Assuming its XP Pro, theres also two different versions: Legal and...
    Speaking of which, can you give some examples of softwares that you ran which require SP2?
  • sshikhar21
    @sshikhar21-NGUChX Apr 17, 2008
    I think U should update ur windows first
    then it will definitely support
    the latest softwares which u want to
    install
  • prabhat kumar
    @prabhat-kumar-KhhWSv Apr 25, 2008
    u must follow instruction.and re instaal the window
