Problem with ultrasonic sensor HC-SR04
dossdss
@dossdss-4lCGQo โ€ข Oct 26, 2024
i have one new HC SR04, i have few serious doubts about it...
1. how can i test it.
2. i tried watcing its echo on DSO but it was not observed, so how can i do that ?
3. i am trying to interface it with ATMEGA16 MCU with a trigger from controller by giving a high pulse of 15us and then waiting for the echo but did not get anything..
so can you pleaz guide.thanks.
  • piyushh
    @piyushh-O70sb6 • Mar 16, 2013
    Not sure but still my suggestion is to go through the data sheet of the interfacing device and the micro controller thoroughly because:
    1. Trans-receiver/micro-controller you are using might have crystal oscillator frequencies incompatible
    2. Different IO trigger voltage levels.
    3. As I can see the module(Ultrasonic Ranging Module HC - SR04) you are using is TTL triggered input, so there can be some issues due to noise margin range
    There can be multiple reason for failure apart from the above but my advice is to please carefully analyse the timing diagrams of both the modules before actually implementing it
  • dossdss
    @dossdss-4lCGQo • Mar 16, 2013
    piyushhNot sure but still my suggestion is to go through the data sheet of the interfacing device and the micro controller thoroughly because:
    thanks.
    i went through the datasheets... and i am trying to do accordingly. but i am not getting how to test that module at least once.
    as you said that there can be noise margin problem, so how can i find that and avoid it ?
