Problem in VB
BCA_GIRL
@bca-girl-wzX9cA โ€ข Oct 14, 2024
Hi CEans,
I'm using Visual Basic 2008 express edition. While creating forms in projects, the form window appeared is not fit to the work space area. I have used maximize button also but it doesn't effects. Can anyone suggest me what to do?๐Ÿ˜•
And, there is an option in form property window that is "Start position". Does it have any link with the form size?
  • PraveenKumar Purushothaman
    @praveenkumar-66Ze92 • May 17, 2011
    No no... See this... You are supposed to adjust the width and height of the form using the properties toolbox. Then, if you have issues while running the application, ๐Ÿ˜ then position the form using the monitor, which is given in the bottom... ๐Ÿ˜€ Simple fix... ๐Ÿ˜€
  • BCA_GIRL
    @bca-girl-wzX9cA • May 17, 2011
    Thanks. But i have set it by reinstalling VB.
    Oh oki... Fine... It would have turned to default values then... But this is the method in case if you get the same problem again...
