  • akravikanth
    @akravikanth-Q0lSIW • Jan 4, 2007
    Its simple,
    System is a class declared as final which cannot be instantiated. It contains various classes and methods.
    The three important facilities provided by the System class are Standard Input, Standard Output and error output streams.
    These are normally called as streams, you can make use of the above said facilities using the following
    out ----> The standard output stream
    in ----> The standard input stream
    err ----> The standard error output stream.
    Normally after creating objects, you will access the functions aka methods
    using dot(.) operator. for example, if a is an object and display() is a method, then u can access by using a.display();
    Similarly, if u want to print, you will make use of the println() method using the dot operator as System.out.println(), where System is the class, out is the outputstream and println is the method.
  • SudhaKar Arjunan
    @sudhakar-iXoJlR • Jan 4, 2007
    System - Has multiple installed function
    Out - Output stream to be printed
    In - Input stream if necessary
    Print ln - to print that partcular line
    Regards,
    A.SK...
  • Manish Goyal
    @manish-r2Hoep • Dec 27, 2009
    not satisfied with answers
    can anyone please throw more light?
  • Mahesh Dahale
    @mahesh-E2tZ3t • Dec 27, 2009
    goyal420not satisfied with answers
    System is a built-in class present in java.lang package.
    This class has a final modifier, which means that, it cannot be inherited by other classes.
    It contains pre-defined methods and fields, which provides facilities like standard input, output, etc.
    out is a static final field (ie, variable)in System class which is of the type PrintStream (a built-in class, contains methods to print the different data values).
    static fields and methods must be accessed by using the class name, so ( System.out ).
    out here denotes the reference variable of the type PrintStream class.
    "out" is an instance of java.lang.system class
    println() is a public method in PrintStream class to print the data values.
    Hence to access a method in PrintStream class, we use out.println() (as non static methods and fields can only be accessed by using the refrence varialble)
    print() is a method of java.io.prientWriter.
    Shortcut for System.out.println()
    you can create a PrintStream variable, assign System.out to it, and reference that object from the new variable instead.
    import java.io.*;
    public class TestPrint
         private static PrintStream out = System.out;
        out.println(Hello, World!);
        out.println(Testing, one, two, three);
