Please Explain Relay settings
ericsson
@ericsson-QCnbLK • Oct 26, 2024
We are using 10 MVA 110/11 kv Transformer for 6 MW power plant. The transformer relay setting has given (7sj621 siprotech siemens multifunctional relay)
CT ratio 75 / 1 A
Relay code settings
51 Ip> 0.8
Ip>> 13
What is the original tripping value and how did we calculate it.......
please Explain
  • aj_onduty
    @aj-onduty-BvuwMK • Aug 29, 2010
    A better scrutiny of the data sheet, or even a simple call to the vendor will do.(I don't want to sound rude, but this is what I do).
  • d_vipul
    @d-vipul-wP6Syg • Aug 31, 2010
    ericssonWe are using 10 MVA 110/11 kv Transformer for 6 MW power plant. The transformer relay setting has given (7sj621 siprotech siemens multifunctional relay)
    CT ratio 75 / 1 A
    Relay code settings
    51 Ip> 0.8
    Ip>> 13
    please Explain
    Please provide more information to provide you solution........Sorry Friend this information is not sufficient to solve your problem.......
    For more details #-Link-Snipped-#........
    To do settings in SIEMENS SIPROTEC RELAY you need to install DIGSI 4.80 Software with 7SJ61 Device Driver...................
    If you are still facing problems share your problems here I am ready to answer your Query........................
    Regards,
    VIPUL
  • sunnypatel
    @sunnypatel-1Y2moh • Nov 6, 2011
    relay use for haandeling high power
  • Tammy1949
    @tammy1949-wTE1I0 • Nov 6, 2011
    A better scrutiny of the data sheet, or even a simple call to the vendor will do.(I don't want to sound rude, but this is what I do). ​
  • aj_onduty
    @aj-onduty-BvuwMK • Nov 6, 2011
    Tammy1949A better scrutiny of the data sheet, or even a simple call to the vendor will do.(I don't want to sound rude, but this is what I do). ​
    May I know the reason why you re-posted the same statement which I posted? I hope that you would have seen this
    aj_ondutyA better scrutiny of the data sheet, or even a simple call to the vendor will do.(I don't want to sound rude, but this is what I do).
    This is post no. 2 of the same thread. Hope you... well, nothing. I believe that my reputation in CE is a bit tainted. Lets hope I won't need to prove it here! This is disturbing as it really makes no sense.
