    @thebigk Mar 16, 2012
    Welcome to CE. Could you tell us what your project is and what problems you are facing so that engineers here can help you out?
  • Shreyas Sule
    @shreyas-yx6FwP Mar 26, 2012
    I had done a PLC based project in final year. Interested to know more about your ideas.
    @harshad-ukH5ww Mar 26, 2012
    Shreyas SuleI had done a PLC based project in final year. Interested to know more about your ideas.
    Can you please share your project title it may inspire some more addition in project and it may become a new project.
  • Shreyas Sule
    @shreyas-yx6FwP Mar 28, 2012
    Titled "PLC controlled cooling of metal billet", the project consisted of controlling the amount of water required to cool a heated metal billet. The amount of water required for cooling varied directly as the temperature.
    The model was in fact a demo version of an actual sub-process, solventizing of soyabean flakes, in Soyabean Oil Extraction process. Oil is extracted from the crushed soyabeans by spraying of hexane on the non uniform crushed soyabean flakes. The amount of hexane sprayed is not dependent on the mass of flakes. As a result, a large quantity of hexane is wasted.
    So the PLC was introduced to increase the cost efficiency of the process. By using load cells and RTDs we can control the amount of hexane sprayed on the soyabean flakes. PLC was used to control the operation of the solenoid valves to spray hexane (water) on soyabean flakes (heated metal billet). PLC used was Delta DVP-EX. Both analog and digital inputs were used. Programming was done in ladder mode (simplest 😀 ).
  • bhaveshri patil
    @bhaveshri-V4nDnx Jul 13, 2017
    Shreyas SuleTitled "PLC controlled cooling of metal billet", the project consisted of controlling the amount of water required to cool a heated metal billet. The amount of water required for cooling varied directly as the temperature.
    Can u plz mail me ur project details. I wan to work on this project for my final yr project. My mail id- #-Link-Snipped-#
    Thankyou
