What is the minimum intensity of light that a photo diode can detect? and how long can the light be kept for sensing it?0
Dear guest, you must be logged-in to participate on CrazyEngineers. We would love to have you as a
member of our community. Consider creating an
account or login.
Member • Apr 14, 2011
depends on the diode. each diodes detects/admits difference range of frequency. that's why u have red, blue, etc... diodes... of course that diodes will be depends on the materials, doping level... etc...Are you sure? This action cannot be undone. -
Member • Apr 16, 2011
EEnano is correct but using IR sensor will be good for smaller applications.Are you sure? This action cannot be undone. -
just a little bit more information to add on dileep comment if he don't mind.
if you're wondering why IR sensor is good for smaller applications i think you should look at the light spectrum "https://eosweb.larc.nasa.gov/EDDOCS/images/Erb/wavelength_figure.jpg" because the wavelength is much smaller for IR thus it is better for smaller detection. please correct me if i'm wrong😀 so from this you can choose your diode correctly depending on applications
best wishes
EEnanoAre you sure? This action cannot be undone. -
Even an LDR with an LED makes a good combo... Like having those stuff for the automatic water tap... I used laser for some other project... 😀Are you sure? This action cannot be undone. -
@EEnano Good to have you to contribute more information EEnano. I don't mind if you add further information. Thanks 😀Are you sure? This action cannot be undone.
