Performance Appraisals – 5 Key Strengths to Highlight
David A Russell
@david-a-russell-xvCBhT • Oct 26, 2024
Regardless of the industry, company or role you’re in, incorporate the following 5 key strengths in your performance appraisals. There is great emphasis on these values as they form the foundation for a company’s corporate culture, and are critical for its survival and long-term growth.
Key Strength # 1: Focus on customer satisfaction – describe how you contribute to increasing customer satisfaction and loyalty for the company’s long-term growth.
Key Strength # 2: Teamwork and collaboration – highlight how you build lasting relationships with other teams and work collaboratively to achieve common goals.
Key Strength # 3: Open communications – emphasize your willingness to listen to new ideas, or to adopt alternative approaches
Key Strength # 4: Interpersonal skills – stress your ability to work with all levels within the organization
Key Strength # 5: Adaptability to change – illustrate how you’re able to adapt in the face of constant changes in the organization or industry
High ratings in these areas will enhance your technical or functional expertise, and will make you a more valuable player within the organization.
David Russell (author for Phrases For Performance Appraisals)
    @thebigk • Jun 5, 2009
    Thanks for the tips. Could you please talk a bit more about -
  • David A Russell
    @david-a-russell-xvCBhT • Jun 25, 2009
    Hi,
    Customer satisfaction is of paramount importance in any business, regardless of internal or external customers. How you treat internal customers is likely to be how you treat external customers as well. Most companies treasure staff that are customer centric. If you are able to showcase your strengths in this area, you are likely to be seen a more valuable to the organisation.
    Hope this helps.
    David Russell
