  • overridding in java help me to understand the below code.
    zion
    Member
    Updated: Oct 26, 2024
    its a program of inheritance and overridding i understood the whole code except(that line is written in bold and i have underlined that line .It is in class area ) as i could not figure how is it useful and its not creating an object then what does it mean
    class fig
    int num1;
    int num2;
    fig(int a, int b)
    num1= a;
    num2= b;
    int area()
    System.out.println("area of fig ");
    return 0;
    class rect extends fig
    rect(int a, int b)
    super(a,b);
    int area()
    System.out.println(" area of rect " );
    return num1*num2;
    class triangle extends fig
    triangle(int a,int b)
    super(a,b);
    int area()
    System.out.println( " area of triangle ");
    return num1*num2/2;
    class area
    public static void main(String args [])
    fig obj= new fig(2,3);
    rect obj1 = new rect(4,5);
    triangle obj2 = new triangle(7,8);
    fig fiig;
    fiig = obj;
    System.out.println( fiig.area());
    fiig = obj1;
    fiig = obj2;
    //fiig is created in reference sort of something with fig i cant figure out what does fig fiig; means in above lines and how is it useful in program can it be useful in other places..
  • Neeraj Sharma
    MemberMay 31, 2012
    fiig is basically deciding which method to execute at runtime... This is also called as DYNAMIC METHOD DISPATCH in java.
    the above code can also be written as
    fig fiig=new rect(4,5);
    in this case fiig.area() executes the area method of rect class.
  • zion
    MemberMay 31, 2012
    thanx..😀
  • kamba giri
    MemberJun 5, 2012
    nice usage of super class... thanx for your program #-Link-Snipped-#
