Orkut Virus
ankur8819
@ankur8819-Y8pKwX โ€ข Oct 23, 2024
Hi friends....how are u all..
actually i have a problem which i wnt to discuss here.....
whenever i type orkut in my web browser...it displays a dialog box with message...
"orkut is banned u fool..guess who did it........."
something like that...
What could be the problem???
Please suggest some way to get rid of it......
I am Using KASPERSKY antivirus..v 7.0.0.125....
    @thebigk Sep 17, 2007
    Seems to me that you've a virus on your machine which fires up the message every time you access Orkut. I suggest that you download AVAST antivirus (Free, Home Edition) and scan your computer.
    Let us know if it helps.
    -The Big K-
  • Ashraf HZ
    @Ash Sep 17, 2007
    Oh, this is a common virus at my comp labs. This also affects Firefox, I believe. To get rid of it, you need to open the Windows Manager taskbar (ctrl+shift+esc), and click on process. Theres a rouge svchost.exe process under the username you have logged in, in the next column. If you logged in as Ankur, the svchost.exe is run under that. End that process immediately.
    If any doubt, just end any svchost.exe process thats NOT under SYSTEM, NETWORK SERVICE or LOCAL SERVICE.
    Next, open your root drive (C:\) and make sure you can see all hidden files and protected operating files. The folder you want to delete is "heap41a".
    This virus is commonly spread through pen drives. The pen drives are infected with a file called microsoftpowerpoint.exe or something like that, and it is run by an autorun.ini file. Make sure you end the svchost.exe process to delete both the heap41a and the .exe file in the pendrive. Its pretty annoying. Good luck!
  • joe maya
    @joe-maya-QD9uts Jan 7, 2009
    1) Remove the process svchost.exe [There are many svchost.exe but you should only stop the one with your account name on it.]
    2)Remove the folder heap41a if its present in your computer whether hidden or not.
    3)Over.
  • aashima
    @aashima-eO93l9 Jan 7, 2009
    ashOh, this is a common virus at my comp labs. This also affects Firefox, I believe. To get rid of it, you need to open the Windows Manager taskbar (ctrl+shift+esc), and click on process. Theres a rouge svchost.exe process under the username you have logged in, in the next column. If you logged in as Ankur, the svchost.exe is run under that. End that process immediately.
    Thanks Ash. That was good piece of information. I didn't face it on my system but I came across it on another system I was working on. At that time I thought someone might have played a prank with the system's owner. ๐Ÿ˜›
