New to Pro/Engineer modelling
Killswitch_on
@killswitch-on-7bFm9n โ€ข Oct 26, 2024
Hello CEans
I have only recently started working with Pro/E and I'm trying to find the answer to a couple of doubts that I have. I would really appreciate it if someone could help me out with these.
1. I have a sketch consisting of only a few rectangles. I want to extrude each rectangle by a different distance into the plane. Every time I try to extrude, I can only get all the rectangles extruded by the same distance. What should I be doing?
2. I also have to model this crane arm (similar to this - #-Link-Snipped-#), but I can neither use the extrude nor the sweep tool. How should I go about it?
Thank you for your time, I really appreciate it.
-Nikhil
  • ashishgupta652
    @ashishgupta652-nzpKVu • Aug 25, 2010
    hello Nikhil,,.
    u can make ur all rectangles equaaly extruded by editing defination of them and applying the constraint equal on all the same sides of different rectangles and make them equally extruded.๐Ÿ˜€
  • riz
    riz
    @riz-bNR7pJ • Nov 11, 2010
    With your first problem. you need build your part with multiple sketches, or after extruding the part go back and cut the different pieces of your part to length. In a single part file you can have many different sketches making up a piece. Try breaking your part down into simpler pieces. You can only extrude a single sketch to one length.
    I hope this helps.
    I will try to answer your second problem later.
  • riz
    riz
    For the second problem you will have to build an assembly. Thats a pretty advanced model for someone who is new to pro/e. I am assuming you are new to pro/e correct?
    Each part of your assembly will have to be modeled seperately, then assembled together as a composite. pretty much the same as it would be done in the "real" world. realisticly a model like that will take an individual many hours to build, even if they know a number of shortcuts.
    I have four plus years experience with pro/e. currently I use solidworks on a daily basis, they work very similiar, pro/e is more advanced though.
  • Roberthell
    @roberthell-YbOYx9 • Sep 27, 2011
    Hi,
    If you are new to pro engineer, You can try reading materials on #-Link-Snipped-#
    Those explanations are very elaborate.
    Robert
