Need your Suggestion : Is there any demand for VLSI?
deep_patel_kop
@deep-patel-kop-FTNn3D Oct 26, 2024
Hi !
I m final year student pursuing in B.E. electronics and telecommunication stream.........After completing my B.E graduation i m interested to do some extra course WHICH COURSE SHOULD I DO ?......Reply is heartly appreciated ..............Thanking you!!!!!!!!
Regards,
Deep
  • KSHIRABDHI
    @kshirabdhi-Wr6ho2 Jul 30, 2008
    hi, i am also a final year student in BTech ETC ,
    after final year if you want to go for software profession then there are number of short term courses on language such as C,C++,Data Structures OR Java and its versions,for beginners and othe higher courses. But for hardware you should know VHDL,Verilog for VLSI.
    if you want to build a career in vlsi then i would say has a lot of scope in abroad as compared to india and it can beget you a lifetime opportunity
    hope now u can decide
  • Mayur Pathak
    @mayur-ywQKfu Jul 30, 2008
    Good suggestion Kshirabdhi
    Deep are you looking to do post graduation?
  • KSHIRABDHI
    @kshirabdhi-Wr6ho2 Aug 5, 2008
    thanks mayur bt can just help me out to chose a better topic for my final year project
  • aashima
    @aashima-eO93l9 Aug 6, 2008
    Well choosing a Project depends on the subject you're good at and comfortable dealing with.
    As of hardware, better try out Embedded System applications with Micro-controllers, or Micro-processors if you can handle and make that sure you go through all the steps from a scratch i.e. right from PCB designing to the code burning process. It'll be of great help for your recruitment process as well as while in company.
    For software, try your creativity in JAVA or DOT NET fields, they are a basic requirements of companies today, but only if you aspire to be a software technician!
  • KSHIRABDHI
    @kshirabdhi-Wr6ho2 Aug 6, 2008
    hi aashima
    thanks for your reply . but our teacher is asking us to do some project using xlinx or matlab. or can you just give me any idea about any project related to optical fiber communications or in signal processing.actually i really dont know what and how to do.please suggest me someway
  • aashima
    @aashima-eO93l9 Aug 7, 2008
    KSHIRABDHIhi aashima
    Wel MATLAB again would require in-depth knowledge, go for it if you have it. For signal processing, you can try out projects which implement waves' processing like Electrocardiogram (ECG). It uses Oscilloscope for the wave analysis and if signal processing is a basic requirement, you might need to design an internal oscilloscope in the circuit.
  • sauravgoswami
    @sauravgoswami-UAfTlI Aug 7, 2008
    well VLSI projects are easier than DSP, if your digital electronics is strong,why dont ya code a DSP engine using VHDL in Xilinx!!!both will be catered
  • Yuvaraj.S
    @yuvarajs-ZHKo1R Feb 25, 2010
    Hi i'm Yuvaraj i want to know what are basic things needed to start vlsi as my carrer
